Not keeping brake pads the same
Old Aug 23, 2011 | 01:31 PM
redtibby03's Avatar
Vehicle: 03 Tiburon
Default Not keeping brake pads the same
I got my shipment of EBC green stuff pads for the front of my car but the back has regular semi-metallic pads on. They dont need to be changed and theres still a good amount of pad left. How much of a safety concern is it if I leave them alone and only replace the fronts with the EBC's?
Old Aug 23, 2011 | 09:21 PM
If the fronts are worn out, Go ahead and change them. Don't be surprised if the rears wear less quickly; they have less load. If it bothers you, change them now. If it doesn't, and/or you don't have the tool, change them later. I'd leave them until they wore out, unless you are going to be on a track and need the improved braking you'll get with the better pads.
