Do heavy wheels make the ride smoother?
Old Sep 26, 2012 | 06:15 PM
Jonas's Avatar
Vehicle: 2003 Accent
Default Do heavy wheels make the ride smoother?
Shocks and tires held as constant, supporting info if you have it.
Old Sep 27, 2012 | 03:46 PM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
i would assume the weight would dampen out vibrations more effectivly on a heavier wheel.
the key word here is "assume"
Old Sep 28, 2012 | 06:47 AM
wheel_of_steel's Avatar
ABSOLUTELY NOT.
Imagine that you have a ping pong ball and a basketball connected to each other via a spring. If you push the ping pong ball by two inches, it's not going to affect the basketball very much. Now if you exchange that ping pong ball for a medicine ball, moving the medicine ball two inches is going to move the basketball a heap.
If that makes sense to you, exchange the basketball for your car body and the other balls are your wheels of varying weights.
I could rattle on and on about this, but for the sake of brevity, google 'unsprung vs sprung weight' and have a read.
