Shaking Steering wheel question
Old Sep 27, 2012 | 06:14 PM
lod12's Avatar
Vehicle: 2006 Tiburon
Default Shaking Steering wheel question
My wheels are balanced with new tires ad I have hubcentric rings. I have new tie rod ends and no bent rims. What else could be causing my steering wheel to shake between 60-75 mph?
I've always been on 15mm spacers but never had shaking problems till this past year. Im dropped too on Eibachs.
Its driving crazy!!!
Thanks for any comments
My alignment is perfect also.
Old Sep 27, 2012 | 06:22 PM
anything spinning can cause a vibration
axles, the rotors,etc,
in rare events offset of wheel can cause it too
if you got the stock wheels and tires, id try that first
Old Sep 27, 2012 | 07:17 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
you could have a bad new tire.
Old Sep 28, 2012 | 06:36 AM
wheel_of_steel's Avatar
The highest speed limit in PA is 65 mph, I'm dobbing.
In addition to what others have said already, check that your driveshaft harmonic balancer is in place and in reasonable condition.
Old Oct 1, 2012 | 01:59 PM
OTECTom's Avatar
WTH is dobbing!?
Old Oct 1, 2012 | 08:40 PM
One of those words that makes more sense when reading upside-down?
Old Oct 3, 2012 | 07:10 AM
starbuc2's Avatar
My 01 Tiburon as doing the same thing. Had the right front axle replaced and that cured it. Now I can hear just a bit of noise from the left side. I'll probably have to do that one soon.
Old Oct 9, 2012 | 03:25 AM
dobbing: verb
To report someone's actions to a higher authority, with the purpose of getting them in trouble. Typically used by people under the age of six.
Old Oct 9, 2012 | 10:47 AM
OTECTom's Avatar
Snitching?
Speak English dammit
Merica'
