H&R
Im looking at H&R's website for the hubcentric spacers. Question for my 97 tib 1.8L what spacer type do i need - drs or drm??? Also what do both of them mean?? What width do i need 5mm 15mm 20mm or 25mm?? If anyone can help thanks cause i want my bsa 259's to fit no matter what i have to do.
You need them in a thickness equal to the thickness of the bolts that stick out of your rotors. I don't know that measurement offhand, but I would "guess" that 25mm would be enough, but it might be too much.
The inner hub diameter is 2.640" or 67.06mm. I don't know the size of the hub on your new wheels, you will have to have it measured. The inner hole on the spacers will have to be 2.640" and the outter hub on the spacer will have to be the dimention of your new wheels.
It would be cheaper for you to contact your local junkyard and pull the hub assembly, (hub, bearings and caliper mount portion) off a 1999-01 Tiburon or a 1999-2000 Elantra.
Also pick up the front rotors with that assembly.
That would remove the worry about captive rotors ever again.
I have the 25 mm spacers on the rear of my 2001 Tib. But I installed them for cosmetic reasons to better fill out the rear fender wells with the CUDA body kit. I had to cut the ends of the factory studs slightly shorter (about 3mm) so they didn't stick past the spacer and interfere with the rim mounting. revolution2120, I have a bunch of pics of my 25mm spacers on and off the car if you are interested!! wink
