Whats the longest youve gone between brake pad changes?
Old Dec 4, 2014 | 06:56 PM
Zeebone's Avatar
Vehicle: 2007 Tib
Default Whats the longest youve gone between brake pad changes?
I was able to go 3 years before I had to change mine. Getting ready to buy a new set of Hawks since Im getting close to my wear indicators.
Old Dec 4, 2014 | 08:21 PM
Years mean nothing. The factory set on my Elantra lasted 80k miles in the front, still (apparently not?) using the rears at over 200k.
Old Dec 5, 2014 | 05:59 AM
Depends on how much braking you do, and how hard you step on the peddle. My car is still on the original OEM pads, and it's just about 5 years old. But it has a little over 30,000 miles and is only driven 6 months out of the year.
Old Dec 8, 2014 | 10:28 AM
On the Accent I usually get about 30,000 miles out of a set of front pads if there's no racing. I'm still on the factory rear shoes even with all the racing at 198k miles. I'm pretty convinced that they do zero percent of the braking.
Old Dec 8, 2014 | 07:03 PM
WytchDctr's Avatar
Vehicle: 14 EGT 2.0
My LC accent nuked its front pads around 30k; back looked newish. The Elantra sitting outside still has factory shoes on the rear at 140k. Fronts replaced twice a bit before they REALLY needed it.
Old Dec 9, 2014 | 12:32 AM
kurtdu's Avatar
Vehicle: 07 Santa Fe
I usually check and replace the pads after 60k miles or as soon as I start hearing squealing noise.
Old Dec 9, 2014 | 05:49 PM
purchased pathfinder with 53k miles
now have 160k miles
never done front brakes before, did rears shortly after purchase and havent since
so....at least 100k miles on both
Old Dec 10, 2014 | 05:32 AM
2000J25SP's Avatar
Vehicle: 2000 Hyundai Elantra GLS
The original pads and rotors lasted until 110,000 miles. Now at 178k and the rotors are a bit warped. And the rears are still original.
