Should I spend the extra money on nitrogen filled tires?
Old Dec 30, 2013 | 04:53 PM
03tiburongt's Avatar
Vehicle: 2003 Tib
Default Should I spend the extra money on nitrogen filled tires?
Have a wheels and tire package saved in a shopping cart and it's an extra $28 to have all 4 filled with nitrogen ($7/tire). Is it worth it or should I save some money and just get them filled with regular air?
Old Dec 30, 2013 | 07:52 PM
Air is ~80% Nitrogen. The other 20%ish will leak out. You will refill with more 80% nitrogen mixed-gas. Eventually, you are within a few zeros past the decimal of having pure nitrogen, just as if you had paid someone to use nitrogen in the first place.
Yes, there are benefits
No, it is not worth paying extra money on a daily driver
Old Dec 30, 2013 | 08:48 PM
Save the money for sure. It's just a gimmick.
Old Jan 2, 2014 | 01:00 AM
wheel_of_steel's Avatar
I get my tires filled with helium because it's lighter and saves weight
Old Jan 2, 2014 | 04:48 PM
Phantom's Avatar
Vehicle: 99 tiburon
My new wheel and tire package came with nitrogen filled tires but it was free so I went with it. I'd never pay for it though.
Old Jan 6, 2014 | 10:47 PM
kurtdu's Avatar
Vehicle: 07 Santa Fe
Race cars will benefit more in using nitrogen for tires. But for regular drivers, regular air is enough. imho
Old Feb 6, 2014 | 11:56 PM
pandaturbo2's Avatar
Vehicle: 99 Hyundai Lantra
The reason nitrogen is used is because it doesn,t change in pressure as much as air when temperature increases, therefore ideally being able to keep tire pressures more constant under extreme temperatures.. I believe only top end race cars and top qualifying drivers need this very small control of the tire pressures. A road car will never benefit properly from nitrogen and once you have filled them with nitrogen they must only be topped up with nitrogen otherwise it is completely pointless anyway.
I have crewed for a competitive race car team and on the same track and same day ran with just air and ran with nitrogen. No noticeable difference or advantage in lap times or even in tire temps but pressures did show a slightly smaller increase than air, however both went up 3-4psi from set pressures.
Basically if you are that anal, like me check your tire pressures once a week or adjust them to your driving and temperature and weather conditions, which you would/should be doing anyway if you are running nitrogen.
