Brake booster delete
Old Jan 9, 2015 | 05:51 PM
99x3beta's Avatar
Vehicle: 99/ Hyundai /accent
Default Brake booster delete
Just wondering if anyone has done a brake boosted delete on an accent ?? And if there's any kits that may work for the accents with out doing crazy modifications ?
Old Jan 9, 2015 | 07:50 PM
Brake booster delete IS a crazy modification.
Old Jan 10, 2015 | 04:21 AM
wheel_of_steel's Avatar
Why would ya?
Old Jan 10, 2015 | 10:32 AM
tibbytib's Avatar
That's what I'm wondering?! What's the benefit?
Old Jan 10, 2015 | 12:11 PM
why stop at just the booster?
why not remove the entire brake system. who needs it anyways and its just added weight
Old Jan 10, 2015 | 03:17 PM
99x3beta's Avatar
I'm trying to upload pictures but I've seen it on slot of Hondas for a super clean look idk if there's an alternative part they may use or what...
Old Jan 10, 2015 | 03:50 PM
tibbytib's Avatar
Oh, I see, your trying to shave the fire wall and I assume do a wire tuck. Hmmm... Seems pretty ballsy to want to completely remove the brake booster. Never changed one either. Not sure if it can be relocated or not. Thats what I would look into if I were you.
Old Jan 10, 2015 | 06:52 PM
The brakes could be boosted with an electric booster, and you could get rid of the (larger) pneumatic one currently on the firewall. Depending on the master cylinder you use, you will probably have to redo all the brake lines which is anywhere from fiddly to a huge PITA, but definitely do-able. To get rid of the brake master cylinder on the firewall would be quite a trick, and you would have to have a totally different style of brake pedal.
Old Jan 10, 2015 | 09:12 PM
XGODZX's Avatar
Vehicle: 1999 Elantra GLS Sportswagon
Old Jan 11, 2015 | 08:00 AM
Negative's Avatar
Vehicle: 1997/hyundai/Tiburon
I was driving with no booster for a about 3 months, just need some leg muscle
