Slime?
Old May 21, 2013 | 01:01 PM
FeelTheFX's Avatar
Vehicle: 1999 Tiburon FX
Default Slime?
One of my tires has a small leak in it. Not sure where its coming from. I cant see anything that may have punctured it. They're about a year old and still have good tread but they're out of warranty. Anybody ever tried some of the sealants out there like Slime? I seen it on the shelf at a Pep Boys
http://www.slime.com/shop/tire-sealant/
Old May 21, 2013 | 01:45 PM
Tibbi's Avatar
Don't use that stuff. It gets all over the rim and becomes a hassle to clean off.
Take it to a tire shop and have them plug (not patch) it. That's cheap enough and makes a great seal in most cases, that is unless its on the sidewall and then you're SOL.
Old May 21, 2013 | 02:14 PM
Do you have a Discount Tire / America's Tire in your area? They do free tire patching/repair even if you didn't buy from them.
Old May 21, 2013 | 03:06 PM
out of this entire statement the only thing i agree with is dont use slime
patches work better than plugs, plugs can fall out while driving. plus to me, fixing a hole by making a bigger hole sounds pretty retarded.
sidewall punctures can be fixed and are legal to do so
Old May 21, 2013 | 06:33 PM
Tibbi's Avatar
I've never had good experience with patches personally.
As for plugs, the hole is ground out more to remove burs that could damage the plug, I've never had a problem with any plugged tire. As for side wall, you can, but I'm of the old school paranoia.
More to the point, Slime/fix-a-flat, etc =
Old May 21, 2013 | 07:13 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
a lot of places won't touch or work on the tire if they know or you tell them there is puncture seal or slime in it.
I worked as a grease monkey at a GM dealership years back and we patched tires (it's called vulcanize). If done right, it's a much stronger/better repair than a plug. Either is better than anything in a can.
Old May 21, 2013 | 08:00 PM
The main question is where is it coming from. You could have corroded RIMS and leak from there. Get yourself a spray bottle with soapy water and inflate and remove the wheel. Spray the whole thing down and where it bubbles, it's leaking.
Slime is for high-reliability-requirement automotive tires, people who don't ask for advice, and bicycle inner tubes. If you don't 100% NEED to be up and running, with never ever stopping for inflation after running over nails or whatever, use slime. Everyone else, use patches or plugs. I had a tire that I drove BALD that had 5 plugs in it and none of them leaked* but if I were going to have someone else work on a tire, I'd have them patch it from the inside.
If there's a cut on the shoulder, that might kill a tire. I'm not a fan of patching sidewalls but a small hole might be alright to patch.
*Even after repeated rotations, none of the other tires would collect road debris, just that one! Must have been magnetic rubber or something. The plugs didn't leak though so whatever.
