- No one using nitrous anymore?
- Giggle giggle
- Hard lines
- People getting rid of their nitrous tanks
- Does anyone leave their nitrous in all winter?
- dual bottle set up
- Street racing tip #187: How not to spray your car with Nitrous.
- Safe with run low octane with nitrous?
- Bottle position
- Nitrous Precautions
- Pretty cool bottle heater
- Is it safe to use a really old bottle?
- Nitrous oxide change 0-100 times much
- Cool nitrous set up
- Is the stock head gasket fine for nitrous use?
- Steel lines vs braided lines
- Best nitrous kit for a tiburon
- Zex Safe Shot Kit
- Nitrous Bottle Storage Requirements?
- How come nobody uses nitrous anymore?
- Torque Steer
- Inline fuel pump boosters
- Pressure Regulator
- altitude and nitrous
- 50 shot dry kit ok to run?
- Mounting bottle in the back seat
- Who has burned up a piston or two from using nitrous?
- Nitrous oxide: The car killer?
- Velosters with nitrous
- Anyone spray in the winter?
- Bottle weights
- Interesting theory?
- Will this nitrous kit be ok for my Accent?
- Dependable nitrous
- nitrous vs. outside air
- Which gears
- Nitrous in my Genesis
- Can nitrous bottles be over filled?
- RPM Vs Time based progression
- Fused bottle blanket
- does anyone have custom colored n2o lines?
- nitrous in the lines, how long should it stay?
- Upgrading fuel pump for nitrous
- Idea Bottle Pressure
- Where did you mount zex control Box
- Will nitrous cause your cat's to clog up quicker?
- Nitrous with the stock turbo
- Putting a NOS bottle in just for a show?
- Nitrous computers that spray a selected amount
- Bottle Temperature vs Bottle Pressure
- How high of an RPM to you spray?
- Any progressive controller set ups?
- ZEX system install questions?
- Wet shots
- 35 Dry Shot
- Uneven Distribution
- How many people still use nitrous daily or weekly?
- Plug Gaps
- Higher octane
- Dry 50 shot too much?
- Mounting of the Solenoids
- Is nitrous use declining?
- thermostatic bottle heaters ?
- Any Genesis owners with nitrous?
- Premium Fuel
- tubing size matter?
- Reading Plugs
- Confused on Remote Bottle Opener
- Blown engines
- Building your own nitrous kit
- TPS and ZEX kit
- NANO Nitrous
- A Great Book On Nitrous Oxide....
- Stealth installs
- freeze the nitrous bottle???
- Solenoid Maintenance?
- Bad to leave nitrous bottle open all the time??
- Any Gen Coupe owners using nitrous yet?
- Sorry if this a major n00b question
- Purge pics
- platinum plugs
- EGT drop
- Would a NOS purge kit work with a Nitrous Express set up?
- Pipe size
- Empty bottle
- What causes intake detenation?
- Spraying info I couldn't find
- All-in-one gauges?
- Are you using a fuel filter?
- Auto VS Stick
- $1,100 for a nitrous kit?
- How did you run your lines?
- Possibly to hit 13's with a 75 wet shot?
- Can I safely leave bottle in trunk all the time?
- Question on Spraying
- Local speed shop near me stopped selling nitrous
- Where should I put the electronic N20 gauge sender?
- Finally bought nitrous system!
- Home made bottle warmer
- Is spraying with bad o2 sensors harmful?
- Is ZEX rated at crank?
- ZEX controller...how it actually works
- Safe Fuel System by Nitrous Express
- Duel stage fogger setups
- Anyone tired of their nitrous kit?
- For the people who have fake turbos, fake FMICs, and fake BOV's
- Is it normal?!?
- Has anyone dynod their car with nitrous yet?
- Went and bought myself a zex kit
- Tapping fuel rails
- Push button switches
- going from a 50 shot to 75 n2o
- What plug wires should I use with nitrous?
- E85 and nitrous
- ZEX or NX?
- Good spot to mount solenoids
- Jacobs Nitrous Mastermind
- Nitrous for low end torque?
- People who have more than one bottle
- If wet kits are the way to go
- question regarding wet system
- Would this zex kit be ok for my elantra?
- 1/4 mile times with different shots
- Wiring a Zex Kit
- Can nitrous be detected if you remove it?
- Anyone ever get a ticket or get in trouble for having nitrous in their car?
- Do you consider nitrous NA or Boost?
- What does a 75 shot really equal to?
- Biggest shot on stock clutch?
- Do you have to retard the ignition with a 75 or 100 wet shot?
- Bottle heater
- Thinking about buying this Venom kit
- NX wet kit
- Which gauge to use with nitrous - wideband or narrowband
- 200 whp
- Is it ok to mix up nitrous parts?
- Whitch one to buy?
- Line Pressure Drop
- Launching on Nitrous
- Frozen line and solenoid
- Nitrous intimidation
- Question about mounting location
- Nitrous jetting confusion
- Wet Nitrous Fuel Supply Question
- Just ordered a Zex kit
- Safe shot
- Having trouble. Spraying air?
- What is needed to safely run a 150 wet shot?
- Steering wheel activated switch
- NX Piranha or Shark nozzel?
- Which spark plug manufacturer is the best for nitrous
- Are blow down kits a waste of money?
- Nitrous 'port injection'
- Tuning with a 75 shot
- Just bought an NX Proton Kit
- Nitrous nozzle placement
- How many miles do you all have on your nitrous injected engines?
- zex fuel question
- Nitrous trouble
- Lean shut off switch
- Air/Fuel
- Nitrous gauge on A-pillar
- May be a stupid question
- NOS Sniper Kit
- I wanna upgrade to direct port.
- DENTED BOTTLE!
- Is one company any safer than another?
- Is using nitrous cheating?
- Do nitrous solenoids go bad?
- Zex Safe Shot kit
- Question about bottle heaters
- Where do you purge your nitrous from?
- single, progressive, or stages
- Post your nitrous set ups
- Is this possible?
- NX N-intercooler sprayer
- Nitrous + megasquirt = good combo?
- Zex NOS & BOSH Platinum plugs?
- Nitrous costs
- Intercooler Sprayer DIY
- Zex maximizer kit
- What makes Venom so much more expensive?
- New Toy
- thinking of installing a small shot
- age old question
- nitrous in cold temps
- Zex Wet Kit
- how much does it cost to fill a bottle?
- tuning
- tib nos
- Nitrous Oxide Master FAQ List
- What to know about nitrous oxide
- Ready For Nos?
- Nitrous Question (another One!)
- Msd 6211 And Nitrous Help
- Nitrous And 1.8ecu
- Nitrous Ruined My Glasspack
- 1.8 Cam With Nitrous
- Zex Dry Kit (75 Shot)
- Nitrous Oxide Legality
- Nitrous Backfires
- Wet Shot = Cleaning Maf Needed
- Question About Nitrous
- Is This A Complete Zex Nitrous System?
- Nitrous System Jet Sizing List
- Nitrous Info Request
- Who's Spraying?
- Looking Into Nos
- Nitrous Components
- Nitrous Questions
- Nitrous Question
- Nitrous Jetting Chart
- Direct Port Nitrous
- Another Nitrous Thread!
- My Nitrous Options. Explainations Needed
- Couple More Nos Questions
- Questions For Those Who Spray
- Why Don't You Have Nitrous???
- What Is Necessary To Know About Nos?
- Nitrous System..
- Dumb F'in Question About Nitrous
- Thinking About Running A Nitrous Set Up
- Nitrous
- what is the best shot of NOS 20, 30, 50,
- would this be safe (nitrous)
- WET v.s. DRY
- ""No2""
- best nitrous system
- people with NX kits or had NX kits please aid me some
- nitrous nozzle
- nitrous question
- Nitrous and turbo question.
- Nitrous question....
- NOS!!! (NITROUS - NOS IS A BRAND NAME!!!)
- Nitrous mounting location help
- Fuel Pump for Nitrous use
- 50 shot?
- Direct Port?
- Nitrous window switch
- Nitrous = Higher RPM?
- wet vs. dry nitrous?
- Nitrous System
- SAF-C work with nitrous setup????
- Pump and exhaust?
- Is the tiburon block infact a 4g63
- Funny Nitrous Video
- Having a problem with the 60 shot!!!
- 14.3@99mph *updated*
