Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) This forum is for Nitrous Oxide discussions, and an area for folks to ask questions about Nitrous Oxide and related parts.
Wet Nitrous Fuel Supply Question
Old Sep 10, 2010 | 01:48 PM
AtomicX's Avatar
Default Wet Nitrous Fuel Supply Question
Hey i'm installing a wet nitrous system and I was wondering where to get the fuel from.
Right now I have a Aeromotive FPR and the left side of it the hose goes to the fuel rail while the bottom of the FPR
the hose goes to a tiny metal line. Which one do I branch off of? Here are the two pictures:
Old Sep 12, 2010 | 11:39 AM
i8acobra's Avatar
Vehicle: '14 Ford F-150
The hose going to the fuel rail is pressurized. The hose on the bottom is the return line and is not pressurized.
Old Sep 12, 2010 | 04:17 PM
JonGTR's Avatar
If you have a FPR, there should be a port on the other side that you're not using. You can get a fitting to supply your nitrous by your FPR. If your FPR uses a -8an fitting, then you can get a -8an bulkhead to 4an fitting. Then run a braided line from there to a 4an fitting on the fuel solenoid.
Or, just cut into the stock fuel supply line with a fuel tee that came with the "import kit".
Old Sep 12, 2010 | 05:35 PM
AtomicX's Avatar
QUOTE (i8acobra @ Sep 12 2010, 01:39 PM)
So which would be best, the pressurized line or non-pressurized.
Old Sep 12, 2010 | 05:50 PM
You want the pressurized one. The one which they thoughtfully placed the rubber section which is perfect for Teeing. The other one has no pressure so it's not really good for anything except returning fuel to the tank.
What brand fuel rail is that? It looks very nice.
Old Sep 13, 2010 | 04:48 AM
AtomicX's Avatar
QUOTE (DTN @ Sep 12 2010, 07:50 PM)
This is my setup.
http://turbosocks.com/store/index.php?main...gnsbt45s48j8e24
Old Sep 18, 2010 | 09:36 AM
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
DTN, it's just a stock rail tapped and painted
Old Sep 18, 2010 | 10:09 AM
It does not look painted. It looks polished.
