Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) This forum is for Nitrous Oxide discussions, and an area for folks to ask questions about Nitrous Oxide and related parts.
tuning
Old Aug 17, 2009 | 08:24 PM
omeletduefromage's Avatar
Vehicle: 02/hyundai/accent
Default tuning
im planning on running a 50 shot with a wot switch. im not sure weather or not to use a dry system or a wet. in your opinion which would be better for a map sensor based car. what should i use to tune. can a safc handle it?
Old Aug 18, 2009 | 07:25 PM
I would say wet, and you shouldn't really need much for tuning a decent wet kit.
Old Aug 19, 2009 | 08:46 AM
hyper25's Avatar
Vehicle: 2000 carbon tiburon
Wet Kit and no tuning is needed for a 50 shot NX KIT for the win.
Old Aug 19, 2009 | 12:49 PM
nice nice, i like what i here, what if i go up with a 75 shot, do you think i would need tuning then? cause thats the most i would ever run through it
Old Aug 19, 2009 | 01:20 PM
No. Tuning in general is for your car all the time. Nitrous specific tuning would only happen when you're spraying and that's handled by the wet nitrous kit hardware with minor adjustments by your ECU.
Old Aug 20, 2009 | 02:15 PM
perfect, im gunna pick up a zex wet kit and run a 50 shot, and go two steps colder on my ngk iridium plugs and should run good.
Old Aug 13, 2010 | 02:26 AM
Tony Vendetta's Avatar
what if your planning to spray 100-150 shot, with a build motor. Would having megasquirt ecu, 650cc, and 255 fuel pump help with a tune?
Old Aug 13, 2010 | 11:29 AM
Then you would need more cowbell. Seriously?
Old Aug 13, 2010 | 12:15 PM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
IMHO anything above a 75 shot needs a dedicated tuner. I'd get something with a program switch so you have a tune with Nitrous and one without. Arm the nitrous and it switches the program. Simple, easy, and most of all SAFE! smile.gif
Old Aug 14, 2010 | 01:40 AM
koreancorvette01's Avatar
for every 75 to 100hp go a stage colder plug to be safe. If your gonna runa 75 drop to a NGK BRE6. Factory is 5 , with NGK's the higher the number the colder the plug. FYI
