Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) This forum is for Nitrous Oxide discussions, and an area for folks to ask questions about Nitrous Oxide and related parts.
Tuning with a 75 shot
Old Jul 6, 2010 | 09:25 AM
Jason99's Avatar
Vehicle: 99 Accent
Default Tuning with a 75 shot
Other than better fuel supply and better (colder) plugs, do you really need to do any other tuning (ECU wise) for a 75 shot or will stock ECU settings be ok?
Old Jul 6, 2010 | 09:28 AM
Bommello's Avatar
As long as it's a wet shot you should be fine.
Old Jul 6, 2010 | 06:00 PM
The ecu is not even aware that nitrous is used because it is run in open loop mode. There are no sensors involved. You will be fine with out a upgraded fuel pump. It never hurts though.
Old Jul 6, 2010 | 06:02 PM
JonGTR's Avatar
Get the fuel pump. Eclipse stocker will do.
Old Aug 13, 2010 | 02:13 AM
Tony Vendetta's Avatar
So I upgraded to nitrous (Instead of turbo) I was told it was a 50-70 wet shot. I tried it and the rpm jump caught me slipping and let go because of sudden rpm jump. Through out the run I sprayed and I did feel a really big pull, but after my check engine came on.....my oem exhast manifold is crack, is it possible that the nitrous some how damaged the cat?? Also now my tibby sounds beast, like if I had stage 3 cams lolz.
Old Aug 13, 2010 | 03:26 AM
iheartmyrd's Avatar
Vehicle: 1998 Hyundai Tiburon
if its loping you prolly fried your plugs bud.
Old Aug 13, 2010 | 07:39 AM
JonGTR's Avatar
You were TOLD it was a 50-70 shot? You should KNOW this info before doing something like that.
You'll also need a clutch for 50+hp. My stocker slipped at a 60 shot.
Old Aug 14, 2010 | 04:47 AM
No worries on clutch, am running stage 3 smile.gif and no the plugs when removed were fine and in good condition, currently running ngk v power now. IDK exactly what happened but am under suspicion that the nitrous blew up my manifold and or o2 sensor. The cars leak got worse and now it really smells sad.gif
Old Aug 14, 2010 | 08:27 AM
If it's a stock exhaust manifold, remove the nitrous stuff and go to a dealer, and they should replace the manifold free (if it is welded to the cat)
Old Aug 14, 2010 | 10:21 PM
Yes it is the exhaust manifold welded to the cat. What exactly do I tell them? recall for a 1998???
