Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) This forum is for Nitrous Oxide discussions, and an area for folks to ask questions about Nitrous Oxide and related parts.
Safe with run low octane with nitrous?
Old May 12, 2016 | 12:20 PM
terjit's Avatar
Vehicle: 1999 Tiburon FX
Default Safe with run low octane with nitrous?
With a wet kit, is it safe to fill up with 87 octane fuel or should you always be using 91 or 93 when you know you plan on using nitrous? This is with a stock ECU obviously and no tuning.
Old May 12, 2016 | 01:33 PM
tibbytib's Avatar
Hmm, well......not sure you should be using nitrous if you are asking this question. Just saying.
Old May 12, 2016 | 01:51 PM
i8acobra's Avatar
Vehicle: '14 Ford F-150
Sounds like some Google education is in order. There's a lot you need to know about nitrous before you try to use it.
Old May 13, 2016 | 05:54 AM
Always use higher octane.
Old May 17, 2016 | 02:35 PM
03tibe85's Avatar
Vehicle: 2003/Hyundai/Tiburon
Any time you increase the amount of oxygen going into the combustion chamber you need to worry about detonation. I would say if you had someone way to retard your ignition timing when the N2O was active you would be fine on lower octane fuels, but since you don't you would be relying on the Hyundai computer to sense the knock and retard. Problem with that strategy is that when your off the bottle the ECU would add the timing back in over time so when you hit the switch you would probably detonate again.
You may be able to get away with a really low shot and not detonate but to quote Clint "Do you feel lucky, punk?" lol
