Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) This forum is for Nitrous Oxide discussions, and an area for folks to ask questions about Nitrous Oxide and related parts.
Having trouble. Spraying air?
Old Aug 26, 2010 | 10:42 AM
conscience's Avatar
Vehicle: 2001 Tiburon
Default Having trouble. Spraying air?
When i first set my kit up it worked great. Then all of the sudden i was just going rich when i sprayed. Also now when i purge their is a tiny white ring around the nozzle and then a large clear cloud of air. You can stick your hand in it and it feels like wind.
A friend said it was the pick up tube. So i pulled the valve off the bottle and it looks find the tube is clear and connected to the valve fine..What could be happening? help.gif
Old Aug 26, 2010 | 10:51 AM
You need a fill up. It sounds like you are out of nitrous. Also, it could be a blockage somewhere In the line between the bottle and the T for the purge/injection or the nozzle on the bottle is not opening fully.
Old Aug 26, 2010 | 08:45 PM
Don't take offense, I've never seen your set-up but . . .
Your bottle IS mounted properly, right? Tilted, and right-side up?
Old Aug 26, 2010 | 09:10 PM
Good point... The tubing inside may be up instead of down... I totally forgot about that. Try rotating the bottle.
