Nitrous Oxide (NOS, Zex, NX Express, Venom, etc) This forum is for Nitrous Oxide discussions, and an area for folks to ask questions about Nitrous Oxide and related parts.
Post your nitrous set ups
Old Apr 14, 2010 | 09:32 AM
2001hyundaired's Avatar
Vehicle: 2001 hyundai Tiburon
Default Post your nitrous set ups
I would like to see some of your nitrous set ups if possible. How do you have your bottles mounted, solenoids mounted, lines hidden under the hood and in the car, etc. Also where did you mount your button/trigger? Thanks!
Old Apr 14, 2010 | 09:48 AM
i had the bottle INSIDE my sub box
solenoids mounted under the intake manifold
nitrous lines wrapped in rubber hose
used a injen style metal elbow piece and sprayed it from the bottom
looked like a vacuum line
the actual nitrous line was routed under the passenger seat, along side the wiring harness by the door sill, through the wiring harness for the door, into the fender well, through the frame rail, then wrapped in hose along side the factory gas lines to the solenoid
that was the racing in mexico setup with a 5# bottle...
the other setup used a 10# bottle mounted directly to the passenger rear floorboard lol
trigger was just a regular button on the dash BUT it was inline with my fog lights
if anyone asked i just said it was my fog light switch lol
Old Aug 15, 2010 | 02:20 AM
Tony Vendetta's Avatar
that setup sounds aswome! You just gave me a great idea on how to hide my lines and solenoids smile.gif
Old Aug 15, 2010 | 08:39 AM
I took alot of time measuring lengths and comparing angles. I wrote this DIY when I was done. This gives you every bit of information you would need for a 2001 Hyundai Tiburon.
https://www.hyundaiaftermarket.org/forum/in...2928&hl=zex
Old Aug 15, 2010 | 09:22 AM
JonGTR's Avatar
NX Direct Port with 15lb bottle and custom braided feed lines to Pirahna nozzles. NOS Progressive Controller and PLX Wideband. 2-12" Eclipse subs and Earthquake amp.
Click:
Old Sep 2, 2010 | 01:42 AM
hey jon how did you go about drilling those direct port NOS lines??
Old Sep 7, 2010 | 01:23 PM
JonGTR's Avatar
It is not NOS, it's Nitrous Express. I drilled a hole, then used a 1/8" NPT tap so that the Piranha nozzles screwed in.
