Post your nitrous set ups
I would like to see some of your nitrous set ups if possible. How do you have your bottles mounted, solenoids mounted, lines hidden under the hood and in the car, etc. Also where did you mount your button/trigger? Thanks!
i had the bottle INSIDE my sub box
solenoids mounted under the intake manifold nitrous lines wrapped in rubber hose used a injen style metal elbow piece and sprayed it from the bottom looked like a vacuum line the actual nitrous line was routed under the passenger seat, along side the wiring harness by the door sill, through the wiring harness for the door, into the fender well, through the frame rail, then wrapped in hose along side the factory gas lines to the solenoid that was the racing in mexico setup with a 5# bottle... the other setup used a 10# bottle mounted directly to the passenger rear floorboard lol trigger was just a regular button on the dash BUT it was inline with my fog lights if anyone asked i just said it was my fog light switch lol |
that setup sounds aswome! You just gave me a great idea on how to hide my lines and solenoids smile.gif
I took alot of time measuring lengths and comparing angles. I wrote this DIY when I was done. This gives you every bit of information you would need for a 2001 Hyundai Tiburon.
https://www.hyundaiaftermarket.org/forum/in...2928&hl=zex |
NX Direct Port with 15lb bottle and custom braided feed lines to Pirahna nozzles. NOS Progressive Controller and PLX Wideband. 2-12" Eclipse subs and Earthquake amp.
Click: https://img.photobucket.com/albums/v...h_MVC-047F.jpg https://img.photobucket.com/albums/v...nt_Panel_2.jpg https://img.photobucket.com/albums/v..._Nitrous_2.jpg https://img.photobucket.com/albums/v..._Nitrous_1.jpg https://img.photobucket.com/albums/v...tch_Area_2.jpg https://img.photobucket.com/albums/v...tch_Area_1.jpg |
hey jon how did you go about drilling those direct port NOS lines??
It is not NOS, it's Nitrous Express. I drilled a hole, then used a 1/8" NPT tap so that the Piranha nozzles screwed in.
