- Check engine on bumps
- 2.0L Beta 1 engine question
- Hyundai Accent 2014 engine SWAP
- 2010 Accent blue hatch
- New to tuning. Want to experiment with my 2002 accent
- New to forum 2007 accent
- I need help finding parts (headers/exhaust, ecu upgrade, strut bars, etc) 2000 Accent
- What did you do to your Accent today?
- Beta I/II engine/Trans questions.
- 2007 Accent mods
- OBDII Mode 6 data
- which kind of engine oil
- need help with 2004 rotor upgrade
- Finally bought myself a foam cannon
- no clutch
- How could you make an Accent AWD?
- How long have you gone before changing your timing belt?
- Why wont Hyundai release a turbo accent?
- 2018 Accents are looking pretty good
- Car care is too much of a chore
- After market front grill
- LC's
- Fender flares
- hyundai x3 swap questions
- Beta 2 Swap in a Accent LC2 Automatic
- Stop it
- Engine
- What wash mitt are you using?
- How many people on here still drive and play around with LC Accents?
- Does 3M double sided tape go bad?
- Improving aerodynamics for the track
- Gauge holder
- Realigning body panels
- Warped alpha head/block
- 1998 Hyundai Accent 1.3 L carb settings
- Harness Bars
- 205/50/15 on an Accent
- Searching for new gauges
- WIring up a wideband
- Make sure your coolants levels are good
- Has anybody ever heard of these coilovers?
- Decent looking dash cover mat?
- Desperately need OBD 2 scanner that compatible to x3
- Removing center panel (facia) on x3
- 2007 Accent ECU VIN Programming
- No light backlight on dash
- RESOURCES
- Exploded battery = Airbags deplayed
- Fuel pump compatibility question.
- Starter not firing, relay location?
- 2016 Accent Sport
- NON-power steering how it feels?
- Remove windshield from donor car
- Hello all! New here,1st post.......... :)
- Collant drain plugs on engine location?
- ignition timing adjustment
- LC injector question
- Structulal integrity question
- Oil pan baffles
- 1999 Accent has a 55 pin ECU
- adjustable cam gears
- Accent 2002
- Converting returnless fuel system to return
- where to install ballasts for HID
- Iso. Need 1999 Accent stock engine harness
- 2001 Accent Sway Bars
- What to do when you've hit a brick wall in modding
- Power rating of outlet
- Did your local gas stations switch to winter blend yet?
- 2015 GLS 6Speed
- Bug Shields
- When starting my car it grinds
- Will Hyundai ever release a turbo Accent?
- lc2 with 1.6 dohc and beta2 tranny
- accent grill removal, tranny oil cooler tips
- Old Accents
- opening up cargo space
- transmission oil cooler
- What does everyone think of valvoline oil filters?
- Accent MC retro fit skirts
- Getting Rid Of Swirl Marks
- need help fast
- need accent 1997 wire diagramm
- How much HP can I obtain?
- g4ec 1.5 lc accent
- lc 1.5 g4ec to a 2.0 beta swap
- Need help looking for an old car
- 2010 Hyundai Accent "SR" Conversion Project - Codename: Ripley
- Location of specific fuse
- Accent 2005 1.6
- Surviving with 1 car key
- Sparking belt?!
- Wouldnt be bad with different wheels
- X3 Beta Swap
- proper size for serp belt
- Drugs are bad
- Bodykit Information
- 2014 Accent Hatchback
- Capa Superchargers for Accents
- Upgrading from LC2 to MC, anything I should know?
- 04 Accent GL body kits
- Where can I find these sideskirts?
- D2 Coil Overs
- Anyone ever transport a kayak or canoe on their 3 door Accent?
- 95 accent Questions
- Power Loss
- Rear Brake Adjustment
- Changing oil type after 90k
- X3 coilovers or drag suspension can't find anything
- Timing belt change
- MC owners, Qtr windows loose?
- Said goodbye to my Accent the other day
- Accent with a Veloster style front end
- 08 tib cluster in my x3
- circuit boards
- Rear engine?
- My nuts are stuck
- Kind of wish I had a 2003 now
- Help me find this lip
- Sweet hood scoop bro
- Anyone have experience with hydrodipping?
- Question about auto auctions
- R.i.p Accent
- Trip Computer
- DIY maintenance for apartment dwellers
- Stanced race car?
- Not a single spec of rust on my car
- Transmission swap questions
- Who has the widest tires?
- Hyundai Flip Key
- Any ideas where to find S Coupe mvti *rarest Hyundai in England*
- DMTL WIRING IS FAULTY 2002 ACCENT
- 05 Accent Splash Guards **NEED HELP**
- Jump starting issue
- 2013 Accent Engine Break-in
- need wiring help
- Photo Request. Car Repair Form & Paint.
- Ambient temperer sender
- '05 Hyundai Accent Bumper Assembly
- looking to do beta swap for my 07 accent
- Wheel Bearings
- Accent Destroyed!
- Phanton Grip LSD
- New Member Asks for Your Advices
- Accident damage help after blown tyre
- How cheap is the Accent to drive?
- Polish questions
- accent gps navigation
- I get this feeling sometimes
- Tastefully done
- Accent BBK
- 1.6l tibby-t manifold on a 1.6l accent
- Leaky gasket is "normal"?
- It would look better if it had wheels that fit
- Seat difference between 4 door and 2?
- What makes something a GT?
- Will a stock Evo X turbo manifold fit on my Accent?
- Please dont let this be an Hyundai Aftermarket member
- Engine Upgrade Ideas?
- What made you decide a 4 door instead of a 2 door or vice versa?
- want to find good reliable website for performance parts for my accent
- Accent failed is road worth test. Do you think its stupid reason ??
- Lowering a 2013 accent 4dr
- Getz engine Accent. Fuel Lines.
- do you get offended when someone doesnt signal into your lane?
- £500 Budget on Surpenstion. (about 700-800 bucks)
- Stupid sister
- Alpha Gearbox Upgrade confirmed.
- Very Loud noise from powersteering Belt when starting and before lock to lock
- Exhaust Debate... Back Pressure, Or Velocity?
- Outter tie rod
- Which one of you smart accent owners did this?
- Anyone got any slammed accent pictures please ?
- 1999 Accent steering problem
- Race Capture Pro
- ANNOYING PROBLEM (engine loom Swap)
- Rear wheel studs
- I'm gonna turn my car into something like this
- 2004 Hyundai Accent Turbo
- Woh! Looks crazy
- How do you think this color would look on an Accent?
- Help with wipers jumping
- Bad day.... Bad Things.. and now even Worse.
- Anyone still paying off their Accent?
- Premium fuel in the 1.6 Alpha: terrible MPG
- X3 clear tail lights Eoi
- Beta engine Exhuast Questions
- Cruise Control
- Electricals are going to hell
- Is this 187's car?
- How connect Accent Temp Guage to Beta Engine
- Steam cleaning interior/seats?
- Beta Swapped Accent Engine Clearance
- Did anyone ever make a real coil over suspension for Accents?
- 10mm spacers
- New motor mounts
- Oil Pan shape
- Searching for a short throw shifter
- Do our cars have a form of Limited Slip?
- Alternative Glass Cleaner
- Ign Timing - Engine Stinks- Timing marks -Light backfiring
- Need help.
- Winter weather windows?
- How much did you pay for your accent?
- liquid detergent spill in trunk
- Rear brake upgrade
- Headlight bulbs
- Was there ever a turbo kit made for the Accent?
- HID fog lights
- Cams
- Tuning Megasquirt. Random Handbrake light
- Repair IC cluster
- Hyundai Accent Self tuning Megasquirt video
- altering compression on the accent
- This one isnt bad
- Weakest part on the Accents
- Check out this Accent
- How often do you use cruise control?
- How to remove the door chime in my Accent?
- Gutted... What next... Engine not cranking
- '05 accent in need of coilovers
- Deer vs Accent
- Will this spoiler fit on my Accent?
- Just paid off my Accent
- bodykits
- Is getting the lip closer to the ground better?
- What else can I do to my Accent?
- How to put a 1.6L in place of 1.5L year 2000
- Plenum Spacer
- Tail light red outs
- Tow bar wiring harness for 2009 Accent 4 dr sedan
- Pulsating in brake pedal
- Rear view camera location
- Big Problem with Beta/Turbo Swaps. (cooling)
- Bought a set of these for the Accent
- Whats your reasoning for modding?
- Tacho Wire ?
- Temp Guage/ Tacho Miswiring help.
- Vinyl wrapping roof
- Removal of ECM Cause any Problem ?
- Just thought I'd let y'all know
- Strut Bar Noise
- Getting wheels soon 15x8 +20 offset okay?
- Wheel Recommendations
- Chirping sound
- Key stuck in ignition
- Hey anyone help me find some relays :)
- mileage
- Brakes
- You know what annoys me?
