Headlight bulbs
Old Oct 30, 2012 | 11:19 AM
Red Raspberry's Avatar
Default Headlight bulbs
I'm looking for a somewhat brighter bulb for the headlights.
Anyone use a Wagner BP1210 H4 before? It's a 80/100 watt bulb. There is also a brighter than stock Wagner Part # 9003BL which is the normal 55/60w bulb.
Old Nov 1, 2012 | 05:18 PM
Fintile's Avatar
Silvania Silverstars (ya i spelt that wrong) or like what I did, buy a pair of 5500K halogens. a tad brighter and they have a cleaner look than stock.
Old Nov 1, 2012 | 05:26 PM
I've had the silverstars before and they don't seem to last. Got some nighthawks and they were worse than the OEMs.
Old Nov 1, 2012 | 07:29 PM
hids if its an option
edit stupid phone didnt send the rest
anywho, if you install a higher wattage bulb you run the risk of melting the harness, so look into an upgraded harness(universal is fine)
i have no advice on your bulb though sorry
Old Nov 1, 2012 | 08:28 PM
I don't want HIDs unless I can do it right. IMHO the OEM Accent headlight is the best incandescent one I have ever had. Maybe just get some OEM bulbs?
Old Nov 1, 2012 | 11:22 PM
wheel_of_steel's Avatar
I got splitfire H4s in my LC, they were the same wattage as stock. If there was a brightness difference, it was a placebo.
However the light that they emit is a perfectly neutral white. sh*t is nice.
Old Dec 21, 2012 | 05:40 PM
Skittle_Power's Avatar
Vehicle: '03 Tib GT
Phillips crystal vision ultra work great for me. I got two years out of a pair before one blew. Then I got some HIDs for $32.
Old Dec 22, 2012 | 04:24 AM
I just got a pair of Phillips Vision Plus but have not put them in yet.
I got ran into by a deer this summer and they replaced the right side headlight with a n Eagle Eye aftermarket headlamp. The Eagle Eye is the biggest POS I have ever seen. Horrible bulb and horrible light pattern. I'm looking for a used right side OEM headlight at the moment.
Old Dec 22, 2012 | 03:15 PM
Vehicle: '03 Tib GT
What year is your car. I have headlights and corners(SR clear) available.
Old Dec 23, 2012 | 05:19 AM
2008 hatchback.
