What else can I do to my Accent?
Old Aug 27, 2012 | 04:54 PM
Julez's Avatar
Vehicle: 2008 Accent
Default What else can I do to my Accent?
Right now I have just a short ram intake and a Borla muffler in place of the factory one. I havent really found too much for 2008's so if anybody has some places for me to check out that sell stuff for my car, please let me know. I dont know where to go with it from here. I just want it to be faster.
Old Aug 27, 2012 | 05:06 PM
pas1216's Avatar
Vehicle: 1991 Impulse RS
You can check out our vendors at the bottom of the forum. I think they sell parts for Hyundai's. Maybe someone else can verify?
Old Sep 12, 2012 | 02:57 PM
zero_gravity's Avatar
Vehicle: 2004 Hyundai Accent
without getting into engine swapping and turbos the only thing left is really a header....i have yet to see one for a 2008 but that doesn't mean that it doesn't exist somewhere.
Old Oct 16, 2012 | 12:49 AM
05hacksent's Avatar
Vehicle: 05 Accent
Weight reduction is always an option. Look at getting a fiberglass or carbon fiber hood or trunk. Take sh*t out of it, gut it if that's your style. Also, getting your suspension dialed in will make it feel better and be a little quicker.
Old Oct 16, 2012 | 03:53 AM
wheel_of_steel's Avatar
-semi slick tires
-sway bars
-good shock absorbers (konis, bilsteins etc)
-fiberglass replacement panels
-camber strut tops
etc
Old Oct 16, 2012 | 07:10 AM
You could always do this to your car
Old Oct 16, 2012 | 09:12 AM
Tibbi's Avatar
Which short ram are you using? I tried to get the Hyundai branded one and strut bar that the offered for the 07&08 for our 09, but apparently that vendor cut ties with Hyundai and they couldn't order it.
As for adding power, aside from a ridiculously expensive n/a tune:
full cat-back
headers
CAI
BBTB
Custom ITBs (?)
Isn't there another member here spraying her MC?
obligatory motor swap (gripe)
General stuff:
Rear disc conversion
Coilovers
various suspension parts
Better rubber
Old Oct 16, 2012 | 06:07 PM
XGODZX's Avatar
Vehicle: 1999 Elantra GLS Sportswagon
http://www.kspec.com/main.php?ac_id=179
http://www.sharkracing.com/acecart/b...cate=010700000
Old Oct 17, 2012 | 01:33 PM
Fintile's Avatar
I have the stock manifold from an 08' botled to my 04....you can get headers that fit an 03-05. The bolt patterns the same...not sure about fitment as far as space but you could get a muffler shop to adjust it. Also a nice 2.25" cat back is a good place to start. You said you only have a borla in place of the stock muffler? did you get a cat back exhaust done as well? Sadly you wont see much power gains for the amount of money you will spend to moddify the 1.6 N/A. Also you could get an air flow converter lie the Apxi SAFC II (only one i can remember right now) you could try for a full stand alone using Megasquirt. Ive heard of some decent N/A gains with that. I think there was a guy with 130 whp N/A using Megasquirt, full I/H/E, BBTB, P/P heads, ported intake manifold and beta injectors.
All in all its a personal choice what you do. You will get some decently good sized power just turbo charging it, you could always go for the sleeper "stock" look and Beta swap it and then moddify that. Hell I knew a guy who ran a 100 shoot on his stock motor and was running really smooth with that.
Old Oct 17, 2012 | 07:58 PM
Def think about getting a header and better piping from the cat to your Borla muffler.
