- 2004 Hyundai Accent Modification Tips & Help
- Air bag light on?
- Short throw shifter... torque solutions
- my accent finally beta powered
- home made strut bar?
- Whos running ONLY glasspacks?
- valve springs specs oem
- Accent glow gauges
- New rotors and pads
- gk cluster swap on my x3
- 2011 Hyundai Accent Alarm Bug
- Accent owners - whats your suspension set up?
- Front brake options
- Cone filter not worth a pennie
- Swirl marks
- New 05 Accent - Modifications
- My thermostat died on me
- Picture request by Relay Box Please!
- RB Owners
- Chop chop chop. O crap.. (hyundai loom help)
- small and simple mod
- Back brakes making clicking noise when stopping
- The future of the Accent
- Thinking about buying these sideskirts
- Headers
- Backup cameras
- throttle bodies
- Manual trans is leaking
- 2002 gsi 2.0L swap
- Traded in the Accent
- A quick question about X3 struts
- Dual intakes
- This is a pretty sick looking intake
- 2002 Hyundai Accent 1.3 12V to Beta 1 2.0 Coupe Swap ( wiring?)
- Coil over sleeves
- 2012 Accent or 2012 Fiesta
- Radiator flush DIY
- LED dome light
- New Accent Owner - what would you do?
- Does this stuff work?
- 04 accent
- Accent sway bars
- VIDEO OF THE V6 ACCENT...
- Pillar gauges mod
- shaved door handles
- 98 Accent GSi
- where to get misc. mandrel bent pipe?
- Rear O2 eliminator
- Instrument panel
- transmission rebuild specs
- oil lines
- Bright LED turn signals
- Threshold braking?
- Stance Mindset rims
- belt dressing
- Those who painted their wheels, durability?
- Does the fuel system maintain pressure after shut off?
- Ever replace your SOHC 1.5L cam seal?
- When to replace an Optima battery?
- my accent in 15x8
- any one think that this can fit an accent?
- Outragious opinion: Accents do better in autocross compared to other Hyundais
- Cleaning/polishing CAI pipe?
- kspec clear corners
- Can anyone confirm this bumper-fix technique?
- UK Hyundai help Engine info/ swap.
- open header hp/trq loss?
- X3 Accent 2.4L Engine with 4WD
- accent 04 sway bars mm?
- High Mounted Stop Light.
- Found the Problem
- Camber Correction
- What to do after touch up paint
- picked these wheels up for the accent..
- How well do the Alpha trannys hold up to boost?
- Coolant Flush: Where to dispose of the fluids?
- I hit a skunk last night
- 84,000 miles and putting on new Eibach springs...
- another slow gas fill up thread
- Reverse indiglow gauges
- Did Hyundai stop making the Accent SR?
- why do my clutch bearings keep failing?
- Exhaust Hangers
- where to find
- Anybody have info on this body kit?
- Is there an aftermarket throttle body that maintains cruise control?
- tranny/clutch beta accent
- my EVAP problem - think i found the problem, what to do?
- brakes question
- new problem
- Whats needed to convert to 5 lugs?
- Know your X3s
- 2012 Accent New Owners
- post pics of your beta accents
- LC2 OEM side skirts
- Would any of these fit an accent trunk?
- Hyundai Shocks The World Again As New Accent Beats ALL Sub-Compacts In Sales In First Month!
- Big problem...
- Idles rough on startup and hesitates while driving
- Accent BBK
- How to
- new member and an EVAP question
- V6 Accent 99 From PR!!
- How would a borla or magnaflow muffler sound
- Part Number for GSI Accent
- Rally suspension
- Dynamat wont stick
- Carbon Fiber Hood and Eyelids for '10 Accent Hatchback?
- Coilover sleeve/ Accent strut
- turing a/c on causing stiff brake pedal
- rear wheel problem
- Custom Cat-Back Exhaust Complete!
- Good oil filters
- Proper Launch with a '10 Automatic Accent?
- sway bars?
- White Rims
- Making your own body kit -- cant find the link
- Best way to make tail lights all red
- Auto trans change issue.
- Gas Smell In Oil
- Yellow tree pollen
- wax question
- 2.5" piping too big for an accent?
- New to the Accent
- Low end torque
- Trailer Towing
- New Avatar - Accent SR
- Tachometer Connection
- Would this look too ricey on a 4 door accent?
- Gonna mold this into the dash
- 2012 Hyundai Accent
- 1996 1.5 dohc 5 speed
- two questions please ?
- SRI heat Shields
- Cat Back Exhaust?
- shifting cool
- Megasquirt for X3 ?
- outrageous rear wing going to have to do it
- what do u think of my grille?!
- Topping off the oil
- Turbo Able?!
- WRX like!
- Good scan tool?
- New guy, wanting to Twincharge on Beta
- 2001 1.5L Header?????
- Dual oil catch can setups
- Diagram of Evac System 2001 Accent.
- Are bumper lips better painted or left black?
- SRI for auto cross
- 2001 Engine Swap
- Beta Swap Difficulty/What can be Reused?
- New guy here
- Battery Relocation
- x3 engine swap
- To Fix or not to Fix
- Found the perfect license plate frame for my car
- 2012 - Hyundai Accent - DI 1.6 I4 138 bhp, 31mpg city/41mpg hwy
- Beta flywheel
- Rubbing compound or clay bar
- What does it mean to have a built motor?
- Accent diamond plate mats
- Anyone help me with 'EL glow' dials
- Yellow fog lights
- Question
- How to Find A Good Machine Shop
- my brake swap
- coilover sleaves
- Best/Cheapest place to pick up some Ksport Coilovers?
- SELLING MY BETA ACCENT
- Bleeder screws
- bucking
- AIRRAM in Beta swapped X3
- 2012 Hyundai Accent officially introduced at Montreal Auto Show
- looking to slam the accent in spring...
- totaled the accent
- 02 Accent Transmission Problems
- Rally look
- Crank pulley bolt
- beta swap in accent gt 97
- Will a tiburon type r spoiler fit on an accents trunk?
- 2004 Accent fuel filter?
- shorty antenna
- 1998 accent 1.5 timing belt
- 1.5 sohc help
- License Plate Lights
- aftermarket valve springs with oem retainers
- Brakes and wheels?
- Sonota 2011 2.0T Engine swap Idea...
- turbo beta fuel help?
- Clear Timing Belt Cover
- Decisions, decisions...
- Attempting my first coolant flush ever
- Back from Trashcanistan!
- camber kits
- 4 door fenders versus 2 door
- 2011 Hyundai Accent 1.6L GDI sales begin in November
- G4ED Pulley set???
- Help with some CEL codes?
- Can you swap an 01 ECU into an 03 or will it not work?
- Trying to find info on this spoiler and sideskirts
- Accent 2001 L hatchbatch
- Radiator Cap Issue
- performance underdrive Crank Pulley Kit
- Throttle body swap 1.6L 04 Accent
- accent performance camshafts
- Turbo & Supercharged LC2
- Shaved Accent
- A little something for you Accent guys
- exhaust system for hyundai accent 2010
- Got my last 2 rims
- Idling Funny and strange rattling noise
- Beta swapped Accent by Epic Tuning (pics)
- 2001 Hyundai Accent LC Turbo mod list
- Whats everyones opinion on this?
- MC Accent Cruise questions
- looking for CAI
- I would like to find some near dustless pads
- Some performance question
- How to clear corner 03 accent headlights??
- Floor Mats
- X3 Cat-back Exhaust! Who is interested?
- Hyundai Accent Grille
- If you thought putting fake badges on your car was bad
- Hail damage on my baby
- A/C blowing warm
- TB Coolant bypass for an Accent
- Washer nozzles are plugged
- Getting rid of cigarette smell in a car...
- turbo to 2002 accent sports
- miles/km per tank?
- Lip suggestions
- ACCENT OWNER -- LOOK WHAT I FOUND!
- Exhaust tip yellowing
- Sun strip recommendations
- Do you use blindspot mirrors?
- Short shifter for 08 accent
- problem starting car :(
- Hi, im New to this forum
- Score of a lifetime!
- Rear bearings
- 99' accent short shifter..
- 99' hyundai accent tires rubbing in rear....
- Performance headers
- Where can I get eyelids?
- 4 door love
- Should I be concerned about Hydrolock?
- Newb Buying at auction.
- Domelight, trunk light, instrument cluster and door chime don't work.
- Recommend me a good o2 sensor
