Bad day.... Bad Things.. and now even Worse.
Old Feb 8, 2013 | 12:40 PM
Antonyr123's Avatar
Vehicle: Hyundai Accent
Default Bad day.... Bad Things.. and now even Worse.
Megasquirt as Gone..
Left with No ecu... Cut up engine loom.
Can anyone tell if the 1.3 Engine loom can be completely removed and a replacement one fitted ? Or is it all spliced.
I don't have heart to Scrap it.. Iv come into money problems with court. Over driving offenses.
i do still have the beta ecm and Loom in peices. idk if its locked Because of the key code.
Old Feb 8, 2013 | 12:46 PM
Antonyr123's Avatar
Anyone got a Hyundai Accent loom i can look at or anything
Old Feb 8, 2013 | 03:02 PM
Wish I could help, but I don't have a harness. I think the US market harnesses are different than most of the world anyways.
Old Feb 8, 2013 | 03:09 PM
Antonyr123's Avatar
Thanks anyways
They are removeable without wire cutting ?
Old Feb 8, 2013 | 10:10 PM
Some cars have big connectors and the loom is split inside/outside. The other cars will have a huge firewall grommet. Either way, look for a long removal session at the breakers, or look at eBay. I give even odds you might be able to special order it through your dealership.
http://www.ebay.co.uk/sch/i.html?_tr...at=0&_from=R40
If you can possibly table the project for a while, do that instead of giving up hope. If you can't get it, you are missing something simple because the car is a simple machine. You have money trouble and stress, but that may not be a good enough reason by itself to ditch the project.
Old Feb 9, 2013 | 03:22 AM
Antonyr123's Avatar
Yea i understand. I'll try to get the Beta ecm working on it if that fails.
Ill have remove beta and downgrade.
Old Feb 9, 2013 | 10:51 AM
You still have the old parts around? Putting it back stock and working on the wiring OUT of the car might be a really good idea if you've almost come to the point of giving up.
Old Feb 9, 2013 | 01:48 PM
Antonyr123's Avatar
stock i fitted old loom
I fitted everything and i have made a thread about the problem. Dose the ecm need grounding on case ?
Old Feb 10, 2013 | 07:34 AM
01steve's Avatar
Vehicle: 2000 hyundai tiburon
why did you get rid of the megasquirt? did it break?
