View Full Version : Wanted
Pages :
1]
2
3
4
5
6
7
8
9
10
11
- 2008 Hyundai sonata four-cylinder silver
- Looking for air ram intake
- 99 Tiburon Fuel Pump Assembly
- WTB: RD1/1999 RH Tail Lamp
- Hyundai tiburon RD Air ram intake manifold
- short shifter for RD@ Tiburon (2001)
- 2000 Elantra Wagon Hatch Parts
- camshafts/forged connecting rod (Beta)
- WTB: Accent Suspension Parts
- Genesis Coupe 3.8L Torsen for trade for 2l Torsen
- Needs some parts for rd2
- WTB Power steering pump
- WTB: Power steering res cap
- WTB: RD1 Front Crash Bar. (Found)
- WTB: OEM Shark Wing
- WTB: 1.8L Intake Cam, Crank Pulley, or new HLA's
- Relocation kit
- WTB RD2 high mount stop light assembly
- Turbo setup or airram
- RD1 Bolt on items
- WTB Wiper linkage 2001 tiburon
- ISO 01 tib front bumper
- WTB: 00-01 Tib Front Bumper, Metal trim
- 2001 tiburon coil pack
- 2000 Tib motor mounts
- Coolant temperature sensor harness
- Shark wing
- Need mount brackets for 99 Accent manual trans
- WTB: Obx water pump pulley, rside intake cam gear, r side 70mm throttle body and airam intake manifold.
- top of transaxle nut
- Wtb: rside adjustable intake cam gear and traction bars for 00-01 tib
- RD Interior door handle black screw covers?
- WANTED: Indicator/Wiper stalks
- Wtb front strut bolt
- WTB: Power steering pump
- wtb: passenger rd2 headlight, stock corners
- Wtb Passenger Fender 2001 tiburon
- Need some front end parts
- WTB: Drivers side headlight assembly 01 tiburon
- wtb: 2001 tiburon headlight housing (passenger or driver)
- tranny highest ratio gearbox for tiburon
- Wanted: Pair of RD2 headlight assemblies
- In the market for an AirRam
- 97-99 RD1 parts needed
- WTB:97 rd exhaust manifold..upper section
- Need a drivers side window assembly and passenger side window switch
- Wanted: Windshield wiper arrm nut cover
- WTB: RD2 stuff
- WTB:beta engine damper
- WTB J2/RD lowering springs.
- Turbo parts
- WTB: 5 speed Manual Trans
- WTB: ECU for RD/J2's
- Solid or urethane motor mouth
- Alternator tensioner bolts
- 05/06 Tiburon Dome Light Console w/ Sunroof Buttons
- WTB: 99-01 Beta engine
- GT Tech Rear Lip
- WTB XD2 SEAT COVERS
- WTB RD1 dash surround
- WTB: manual J2 wagon
- WTB: 96-01 Tib/Elantra pass. front strut
- 1.5L Head
- WTB: Gen Coupe Switchbacks
- Fuel pressure regulator screw (14mm)
- Part needed
- 2.0 BETA ECU & Loom Wanted
- WTB tuning software and fuel system
- WTB 17" Factory Tiburon Rims
- WTB: Rside 70mm big bore throttle body
- Parts needed
- WTB: Stock First Gen Gcoupe Tail lights
- WTB [forged piston 82.5]
- cruise control parts
- Bros instrument panel
- wtb: Rear License Plate Housing for the Light bulbs!
- WTB: Greddy Ti-C Exhaust Silencer
- 96'-2001 performance exhaust parts
- 11" Brake Upgrade wanted for 2002 Beta Accent.
- wtb - 2001 tiburon front seat
- 1.6 Accent Engine harness
- Half aluminum radiator
- NEED RD1 Turn signals! FRONT
- WTB: 2000-2001 Tiburon 2.0L Engine
- Wanted: 1996-1997 Tib/Elantra O2 plug harness side
- 2.0l short block and crank
- wtt: a fuctional cd player for ?
- WTB: Rside Advanced Short Shifter and Interior Trim Pieces (Located in IL)
- Looking for Bell Housing
- WTB- Power Steering Pressure Hose
- WTB Hyundai Scoupe Turbo
- Corners
- Need RD1 passenger headlight!
- RD1/RD2 Driver's side knuckle
- RD1 hood/headlight/corner lights
- WTB - Hood Hinges L&R
- 5 spd trans for RD2
- clutch pressure plate for an RD2 (2000 tib)
- WTB or WTT; rd2 single din surround, vehicle speed sensor
- Need Drivers Side Axle
- Looking for Piggyback
- wtb: beta 1 a/c tensioner assembly
- need some turbo parts(injectors,piping,fuel pump)
- Wtb: Rside intake adjustable cam gear
- WTB: beta1 TPS sensor
- Front Bumper Cover Retainer fasteners
- NEED a 2000 Tiburon hood, anyone?
- wtb: fenders
- Power steering pump reservoir hose
- Performance Front Sway Bar 2004 Accent
- 96-99 Tiburon Muffler OEM
- WTB Tiburon turn signal!!
- i need this pretty badly.
- wtb:lowered springs or sway for j2
- WTB: X3 GT tidbits
- wtb: BETA 2 OIL PAN
- WTB Beta II head
- WTB SUPERLUX TAILLIGHTS !!!! L
- wtb: accent 4 2 doors mudguards
- WTB 1.8 intake cam!
- wtb beta swap accent
- Urgent Need! Front Brake Calipers
- WTB - Manual Transmission
- WTB Silver passenger side fender
- OEM Parts Wanted
- WTB RD coilover
- Big Bore Throttle Body wanted for the UK
- wtb - downstream O2 sensor
- wtb- Crossmember bolts
- 3 Pillar Shark Spoiler wanted
- WTB - Rear oxygen sensor and front oxygen sensor female harness
- WTB: accent 2004 speed sensor input (MT)
- WTB RD1 Parts.
- RD2 Front Bumper Metal Reinforcements
- Rd2 motor mounts
- 5 Speed Trans For Beta 2 Motor (02 Elantra)
- looking for stock skirt clips
- Wanted: Kiefco Throttle Position Sensor
- WTB: accent cluster
- WTB: GK rear seatbelts
- Wanted : Cuda Exhaust Beauty RIms
- RD antenna bushing/grommet
- WTB RD1 passenger turn signal and headlight
- WTB: KFX(colt cams) or the Rare SR Cams!
- WTB: HD Engine Mounts (Roll Stops)
- 2001 4cyl 02 sensor bank 1 sensor 1
- Wanted: Hood Seals
- WTB: Stock Accent GT 04-05 Front bumper.
- ELANTRA XD WHATNOT
- XD Adjustable Shocks
- WTB: Non Captive Stuff
- WTB: West Wing Spoiler or oem Shark Wing
- WTB: AEM FIC & UEGO
- 2001 shifter boot
- WTB: RD2 w/sunroof sunvisors
- WTB: RD1 1997-1999 AUTO TRANS FLEX PLATE
- WTB RD2 type-R rear spoiler
- WTB:non captive knuckle hubs for 97 J2 elantra
- WTB: Brake and clutch pedal assemblies
- WTB: stock 1.6L Accent RODS and Pistons
- WTB: Velox vx8 Wheel
- RD1 Short Shifter and 14" rims
- Early Christmas wish list
- Parting Out '98 Tib
- *Urgent Need* Left Rear Caliper
- WTB SS break lines
- WTB: 1996-1999 Tiburon leather shift knob
- WTB: 2001 Tiburon Proportioning Valve
- Looking for stock Fx wheels!!!
- WTB 1998-2001 Tiburon intake
- WTB: LC2 Rear Sway Bar
- wtb: rd2 stock corner, pass handle
- WTB RD2 dash conversion
- WTB XG350 OEM BBK
- Would like to Purchase your Injectors!!!!
- RD2 passenger side Position lamp (and wiring head)
- WTB: exhaust system from header back
- WTB: Valve Cover
- WTB Power Steering Pressure Hose
- WTB: rear H emblem
- 98 99 gsi front bumper
- o2 sensor
- WTB: Bypass plug for the AEM F/IC
- WTB: Air Ram intake
- WTB: Shark wing
- WTB/Trade: 1.6 Stock air box
- WTB: Lowering Springs
- WTB: AEM FIC, and Uego
- WTB: rd1 Rear lip
- For Sale: tanc's big spring/tax season performance/stock parts sale!!
- RD2 interior parts
- Wanted Pistons/rods
- WTB: Dead 1.6l Alpha motor. Ontario, Canada.
- Wanted! - RD2 Tiburon Engine Dress-Up Oil Filler Cap
- WTB Clear Corners RD1 drivers side, RD2 both sides, plus passenger fender.
- WTB: tiburon 2000 HOOD
- WTB: RD2 Sun Visor and Blank Fog switch
- WTB 98-99 Tib exhaust Manifold
- WTB: Valve Cover
- WTB Megan Racing Headers 99 Tib
- WTB: O2 Harness
- WTB: couple of RD2 items
- rd1 catback exhaust
- WTB: Lowering springs or coilovers
- WTB Window Regulator Driver Side
- someone to mod ecu
- Captive Swap Bits
- wtb : rear right rotor
- WTB: Rear tow hook
- WTB: Beta 1 2.0L Exhaust Cam
- WTB Wiper Arms
- wtb: rd2 radio surround
- WTB: TPS Wiring Harness
- WTB: SHARK SPOILER
- I miss my tiburon
- WTB: WTT: 96-99 flywheel
- WTB: Crankshaft Position Sensor
- Wanted: Stock Fuel Injectors
- WTB : RDTIBURON stickers
- wtb - oil pan
- WTB: RD2 BODY PARTS
- airram intake manifold and Rside throttle
- Need stock rear brake lines
- WTB 1.5 Accent engine longblock
- Kefico TPS wanted
- AEM spark plug cover
- Triple Pillar Pod
- WTB: O2 Sensor harness pigtail or broken O2 sensor
- Yaya Poly Bushings
- Seeking 2000 MT Transmission
- WTB: RD2 Leather Steering Wheel
- CAMBER BOLTS
- eaton supercharger
- wtb: rd2 short shifter
- 01' headlamp
- Air Intake
- WTB: Valve cover
- WTB: Beta2 Turbo Manifold
- Twin Inlet manifold
- wanted! airram intake mani WILL PAY!!!
- wtb: rd2
- WTB: Beta 1 Fuel Rail
- WTB: Tib hatch floor/spare tire cover
- Need stock air box for LC2 03-05 Accent 1.6
- WTB or Trade for Stock GK Front bumper and front fenders
- WTB: Turbo manifold for beta 2 and oil pan
- TPS Anyone have?
- Need 2.0 connecting rod
- wtb: rd tiburon tranny
