View Full Version : Wanted
Pages :
1
2]
3
4
5
6
7
8
9
10
11
- air bag srscm module p/n 95910-27350
- wtb: AC lines Beta
- wtb: stock exhaust manifold, 2.0 piston/rod, sunroof gasket
- Need Beta 1 cylinder head
- Looking to buy a parts tiburon
- WTB A arms with spindles/hubs and 00-01 Sunroof console
- WTB: RD2 hood, bumper, rad support+
- ANYONE PARTING OUT AN rd1 TIB????
- looking for rd2 interior stuff
- Wanted: GK Tib front clip (prefer 06') Northeast
- WTB: RD1 Stock Door Hinges and a 2.0 flywheel
- need exhaust
- Wanted: Exhaust
- Wtb: Rd2 Hood
- looking for a wing
- Wtb: Shorty Antenna
- Wtb: Lowering Springs & Rd Tiburon Sticker
- I Need A Passenger Side Turn Signal/marker Light Asap
- Wtb: Thin Fan
- stock fog lights
- Radiator Drain Plug
- Wtb: Tps Clip
- Wtb: Hood Deflector
- Wtb: Rd1 Stock Door Hinges And Possible Black Fender
- Wtb: 2.0 Pistons
- Wtb-5 Speed Parts
- Driver's Side Front Right Seat Track Cover
- Wtb - Intake
- Wtb: Power Steering Lines
- Stock Air Box
- If Anyone Is Parting Out A 2001.....
- Wtb: Stock Suspension
- Wtb: Injector Clips And Harness.
- Wtb: Rear Upper Control Arm (i Think?)
- Looking to buy a good head for my G4EK engine.
- Wtb - Cai Air Filter
- Wtb: Lower Crossmember For A 2001 Tiburon 5spd
- Wtb - Coolant Temperature Sender
- Wtb Flex Pipe Section From Obx Header
- If You're Parting Out, Read This!
- Wtb: New Kefico Tps
- Wtb: Aem Cold Air (blue)
- Wtb Rd1 2l Fuel Injectors
- Rd1 Shark Spoiler
- Wtb: 2 90* Aluminum 2.5" Piping
- Dash Air Vents
- Wtb: Transmission Reverse Switch
- Wtb : Ecu
- Need some Injectors!!!!
- Wtd: Shift Suround
- 2001 Rd2 Tibby
- Wtd: Aem Fic Wiring Harness
- Wtb: 2.0 Engine
- Wtb: Clutch
- Wtb Turbo Manifold And Shark Wing
- Wtb: Passenger Side Door Lock Actuator
- Looking For Lowering Springs
- Braided Steel Slave Cylinder Line
- Wtb: Rd2 Passenger & Rear Leather Seats
- Wtb: Rd1 Fog Light Insert Blanks
- Some One Have Power Pulley For Sell
- some one have Power Pulley for sell
- Wtb:tps Harness
- some one have a megan header or a maintec header
- Wtb: Front/side Markers
- Wtb: Hubcentric Spacers For The Tib, 20mm Preferably
- Looking For Megan Equal Length Header
- 1.8l Ecu
- Looking For 1.8l Ecu
- Looking For Some Type Of Tuning Software (not Soft Wear)?
- Need Some Mirrors
- Gt Tech (or Other) Rd2 Front Lip
- Wtb: Autometer Gauge Clamps
- Obd-2 Software
- Aftermarket Parts
- Need Drivers Side Corner Light
- All New Brakes.
- Passenger Side Wiring And Extra
- Wtb: Safc Neo Or Ii / Wideband With Gauge / Poly Mounts
- Catback & Header
- Wanted Help To Get 6 Rib Pulleys Made For Tib Beta 1
- Wtb Cold Air Intake And Headers For 2000 Tiburon
- Injector Spacer Kit
- Looking For An Engine
- Rd1 Items wanted
- Wtb: Factory Front Bumper
- Wtb Gsx Fuel Pump Or 190lph
- Wtb - Rd1 Eyelids / Eyebrows
- Wtb - "coupe" Badge
- Need Window Regulator!
- Wtb: Triple Pod A-pillar Replacement
- Need Rd2 Center Cap
- Rd1 Driver Side Fender
- Rd1 Short Shifter
- Wtb: Any Tiburons For Sale
- Wtb: Airbag Control Module And Clockspring
- Wtb: Rrfpr, Clear Corners, Lower Control Arm, M3 Mirrors
- Wanted: Injectors, Engine Dampener, A Couple Other Things
- WTB: aem fic
- Wtb Polyurethane Motor Mounts Or =
- Wtb - Walbro Fuel Pump Gss250 Or Gss342
- Wtb Performance Pieces !
- anyone got any rims forsale
- I need some parts
- WTB: Header of 02 elantra
- Wtb: Input Shaft
- Wtb Driver Side Cc And Marker Light
- Valve Cover For 2001 Tiburon
- 97 Transmission Case
- Wtb: Passenger Wiper Arm
- Wtb: Good Used Front O2 Sensor. Or Willing To Trade...
- Wanted : Fog Light Assembly And Position Lamp Assembly (00-01 Tiburon)
- WTB: RD2 Shift Surround and Boot
- Wtb: Rd2 Cruise Control Switch + Manual Shifter Surround
- Wtb: Shift Surround And Boot
- Wtb: Clear Plastic Gauge Cluster Cover
- Wanted Bunch Of Random Parts
- Wtb Aem Wideband W/o2 Sensor, Oil Pan
- Wtb: Release Fork... Need Asap
- Wtb:shark Wing
- Wtb: Power Steering Pump And Rear Seat Knobs
- Wtb Oil Pan Beta 1
- Wtb Stock Rims Rd1 Or Rd2
- Wtb: Shift Fork Lever Arm And Nut
- Wtb 440cc Injectors
- Wtb Ecu And Pigtail
- Wanted: Exhaust, And Headers
- Wanted: Red 2001 Fuel Door
- Wanted: 2.0 Head
- Wanted: Rims/tires And Transmission
- Wtb: Leather Interior
- Wanted: Rd2 Parts Car
- WTB: 1st gen Accent
- Wtf Right Side Power Window Parts
- Evap Canister For A Rd2
- Wtb: 2007-8 Stock Hood And Front Bumper
- Wtb: Se Tiburon Calipers (red Alum Ones)
- Wtb Evo J-pipe
- Hood
- Wtb: Auto Trans
- Wtb Rd2 Taillight Socket, Misc Rd2 Parts
- Wtb Stock Fuel Pressure Regulator
- Need Cam Poss. Sensor, Valve Cover
- Hood
- Wtb: Rd2 Rear Wiper Relay
- Wtb: Rd2 Right Side Mirror
- Need Rims And Tires
- Wtb: Engine Harness
- Wtb: Exhaust, Headers, Intake
- Wtb: Transmission Brackets
- Wtb: Rd2 Passenger Headlight
- Need Driver Side Corner Panel
- Wtb: Rd2 Corners. Stock
- Ckp Sensor Wiring Connector
- Wtb: Rd1 Passenger Fender
- Wtb: Rd2 Part
- Gt Headers
- 1.8 Intake Cam
- Wtb Stock Rd2 Front Bumper
- WTB Stock RD2 front bumper
- Wtb: Airram
- Wtb: Headers Or Stock Manifold
- Bored/oversized Pistons Beta 1
- WTB: LC/LC2 coilovers or springs
- WTB: LC2 rear sway
- Wtb: 2nd Catalytic Converter
- Wtb: Tib Parts Mostly Front End For Rd1
- Rd 1 Turn Signals And Oem Fog Light
- Wtb: Beta 2 Head, Big Turbo Parts, Other Misc Interior Stuff
- Peice Of Center Console
- Short Shifter Or Wing
- Iat
- Wtb Oxygen Sensor
- Wtb: Phenolic Intake Manifold Spacer Kit
- Need C Shaped Retaining Clip For Shift Linkage
- Wtb - 2.0 Fx Exhaust
- Need Alternator Asap!
- Complete Exhaust System
- Wtb: Oem Midpipe Or Aftermarket Midpipe
- Wtb: Steering Wheel Hub 1998 Rd1 Tib
- WTB Alpha exhaust manifold
- Automatic Transmission
- Wtb Turbulence Sideskirts
- Wtb: Xg350 Calipers
- Looking For 01 Tib Front Bumper, Bbtb, Header, Short Throw
- Looking for a wideband
- Wtb Maf Pigtail
- Wtb: Kefico Tps
- Wtb: Maf
- Wtb: 440cc Injectors
- Wtb: Vehicle Speed Sensor
- [wtb] Shorty Antennae
- Wtb: Lightweight Pullies
- Wtb: Beta 2 Head
- (wtb) Stock Headunit 99 Tiburon Fx
- Wanted. Front/Rear strut braces for X3
- Wanted: Stock Tb, Header, Exhaust, Maybe A Cai
- Wtb Power Steering Pump Resevoir And Hoses
- Wtb: Stock Intake Duct
- Rd2 Headlamp Assemblies
- Starter Harness/cables
- Sell Me Everything!
- Need An Rd2 Shifter Surround
- Rd2 Low Beam Moisture Seals
- Wtb: Everything From The Radiator Forward For 2001
- Wtb: Rd2 Gauge Cluster
- WTB:2003-2005 LC center dash bezel
- Wanted Airbag Esps Module
- Wtb: Rd2 Main Dash Plastic
- Wtb: Rd2 Interior Parts/switches
- Front Shipped To New Zealand
- Wtb: Racing Helmet.
- Wtb: Left Front Control Arm, Bothe Fender Liners For 99 Tib
- Wtb: Asap - Reverse Light Transmission Switch
- Wiper Linkage Rd1
- Wtb: Stock Rear Sway Bar Endlinks
- Type R Wing Fitting A 01 Tiburon In Silver
- Wtb: Right Side Rd2 Headlight Assembly
- Wtb: Hub Assembly
- Wtb: Rear Rotors For Cheap
- Wtb Asap: Radio Connector And Some Speakers
- Lookin For Simple Bumper Part
- Wtb: Cat
- Wtb P.s. Clear Corner
- Wtb - Obx Crank Pulley, Water Pump Pulley
- Wanted: Rd1 Sunroof With Intact Seal
- Driver Side Clear Corner Or Both Cc's & Oil Pan
- WTB Rims for a 2001 Hyundai Santa Fe
- Wtb: O2 Sensor Connector
- Wanted : 1.8 Beta 1 Cylinder Head
- Wtb Stereo Surround And Shifter Trim
- Wtb: Rd2 Sunglass Holder/sunroof Control Module
- Wanted: Front Bumper Reinforcement
- Wtb, Engine Mount, Lower Timing Belt Cover
- WTB LC driver's side axle
- Wtb: Used Header And Downpipe
- Wtb: Any Hyundai Ecu (broken Is Fine)
- Wtb: Clutch Alignment Tool
- Wtb: A Tiburon
- WTB: Beta II Engine Block
- Wtb: Dual Fuel Rail
- Wtb: Rd1 Entry-level Tubro Kit
- Wtb (rd 1) Foglights And Lowering Springs
- Wanted: Power Steering Pump Bracket
- Some Wanted Oem Parts
- Connector
- Wanted: Parts For Rd2
