My Build Thread v4.0
Old Jul 30, 2014 | 06:50 AM
  #211
JonGTR's Avatar
For anyone wanting to switch to COP's, here's the wiring diagram. Pretty basic as they're wired in the same as stock.
Old Jul 30, 2014 | 07:17 AM
  #212
Thanks A-hole. That helps tons.
Seeing how jon wired em makes me think we can setup Honda COPs also. They are 3 wire. The aux wire jon didnt use is for a tach signal. Hondas have an internal igniter as well and may be easier to get ahold of(more vehicles use em...civics, s2000, etc)
Old Jul 30, 2014 | 07:41 AM
  #213
JonGTR's Avatar
It's not a tack signal dipshit. It's firing verification. Cars get tack readings from the crank signal.
Old Jul 30, 2014 | 11:15 AM
  #214
JonGTR's Avatar
Here, look these up on ebay. There's plenty of coils there for $20 each or less.
90919-A2005 (I have this)
Not verified:
90080-19015
90080-19023
90919-02234
And the Toyota coils are used on almost every one of their engines, just like Honda. So there's no availability benefit. I provided the wiring diagram for the Toyota and boot verification, so if you want to try something different and spend the legwork on figuring out the pins and whether or not the boot is long enough, then that's your call.
Old Jul 30, 2014 | 02:37 PM
  #215
ScoupeLS's Avatar
Vehicle: 2003 Tiburón GT
I might do this on my RD2. seems fairly easy to do.
Old Jul 30, 2014 | 03:42 PM
  #216
SpoolinShark's Avatar
Vehicle: 2010 Hyundai Accent
COP seems pretty cool. I imagine there is a benefit to this over using a stock setup, correct?
Old Jul 30, 2014 | 04:16 PM
  #217
JonGTR's Avatar
Not unless your boosting to 500hp or more and having to gap your plugs really tight. Or like you said, you want to look "cool".
Old Jul 30, 2014 | 04:28 PM
  #218
Plus you cant control dwell with stock ecu
Dont do this unless you need it. Not gonna get you laid one day
Old Jul 30, 2014 | 04:52 PM
  #219
ScoupeLS's Avatar
I'm running MS and Im' all stock now but I plan boosting my car next spring, most likely go with a Precision 6152E.
Old Jul 30, 2014 | 04:59 PM
  #220
Doing this is the equivalent of putting a parachute on your car cuz it's pretty. On stock it's worthless. Use the money to buy suspension parts.
