My Build Thread v4.0
Old Jan 1, 2014 | 06:18 PM
  #101
JonGTR's Avatar
No, it needs an external ignitor. I'm using one from an Eclipse.
Old Jan 1, 2014 | 06:31 PM
  #102
slow 2K2GT's Avatar
Vehicle: 2003 Hyundai Tiburon i4
An external ignitor from an Eclipse?
I'm not sure how the Haltech works but what are your ignition capture settings?
I use a 78deg trigger angle, 5deg tooth offset, 60-2 trigger wheel and single tooth cam input...hope that helps, maybe the haltech won't fire spark unless the timing points are synced up
Old Jan 2, 2014 | 02:22 AM
  #103
XGODZX's Avatar
Vehicle: 1999 Elantra GLS Sportswagon
After i recently got my G4GF rebuilt and the mechanic couldn't get spark or injection pulse and said he thinks it was something to do with the Haltech but what caused the haltech to crash my tuner and Haltech haven't had a issue with the platinum 500 before but my tuner came to the mechanics workshop and got it to start. Haltech said it's was caused by a dirty signal from crank trigger, there is a crank trigger issue and likely the trigger disc clearance to the sensor may be wrong ,the tuner was able to "filter" the signal.
Old Jan 2, 2014 | 09:41 PM
  #104
slow 2K2GT's Avatar
Jon,
Did you use the ACT clutch disc or one for the Beta? I am seriously considering the change to a push clutch but som thing to hold over 500tq
Old Jan 3, 2014 | 06:25 AM
  #105
JonGTR's Avatar
If you convert to push, you have to use the Eclipse non-turbo clutch. Go to Atelierhp section and contact Denis about the clutch and alternator relocation kits.
Old Jan 9, 2014 | 10:52 AM
  #106
JonGTR's Avatar
I finally got spark, so that's cured. But, when starting the motor I can't get more than half a turn of the crank before the starter gives out. Going to need a new one.
Old Jan 9, 2014 | 06:56 PM
  #107
You're certain it's the starter, not the battery?
Old Jan 10, 2014 | 09:43 AM
  #108
yes jon, since you are new here did you check the most obvious thing ever?
god stocker you are f*cking retarded most times
Old Jan 10, 2014 | 09:44 PM
  #109
Look buddy, I've been working around people in all sorts of industries for a good long while now. Long enough to know that sometimes even a recognized expert needs two seconds of another set of eyes looking at a problem.
Then again, you do have to be a *little* mature to realize things like that don't speak poorly of the expert in question so
Old Jan 10, 2014 | 11:59 PM
  #110
hey jon are you sure you are using the right key?
did you step on the clutch pedal?
are you in the right tiburon?
