My Build Thread v4.0
Old Jan 25, 2014 | 08:16 PM
  #121
JonGTR's Avatar
Done with the lamps and they look great. The car will sit mostly garaged, so I think the lamps will stay clear for a while til I feel like paying for the sealant.
Got the new starter in and it now fully cranks, proving the other starter just lost torque. Autozone said it was still good cause it turned. They probably don't check for how much torque it provides. Anyways, just need to adjust the fueling.
Old Jan 26, 2014 | 03:11 PM
  #122
JonGTR's Avatar
Still messing with the fuel, but all this starting requires a battery at 100%. I've had my Osyssey for several years now and it went dead from sitting. I did some shopping and found that Autoplicity had the best price. I found a secret code:35offshipping that dropped the price to $101.82 shipped. I can't believe how expensive these things have gotten since first used in Eclipses.
Old Jan 27, 2014 | 05:51 AM
  #123
expensive battery is expensive.
I miss the one I had in the pile. sh*t was 600cca sealed gel cel battery. was small enough to hold in 1 hand. f*cking thieves
Old Jan 29, 2014 | 04:59 PM
  #124
JonGTR's Avatar
In the meantime, here's some oldschool sh*t.....
http://www.youtube.com/watch?v=xw34meYxrGw
http://www.youtube.com/watch?v=RImaXyMZjV4
http://www.youtube.com/watch?v=ev4ajWZalDE
http://www.youtube.com/watch?v=yxiWa6ASXHM
Old Feb 1, 2014 | 06:10 AM
  #125
Regit's Avatar
Vehicle: 2000 tib
Cool! , I had the exact same boost guage,but maxed it out ! lol
Old Feb 17, 2014 | 08:01 PM
  #126
JonGTR's Avatar
DO NOT BUY FROM AUTOPLICITY!!!! 3 WEEKS AND NOTHING BUT EXCUSES.
Old Apr 12, 2014 | 10:25 PM
  #127
BUMP
Old Apr 14, 2014 | 10:02 AM
  #128
tdonnell's Avatar
Hey guys! Its good to see there are still some "veterans" on the forum! I recently killed my engine on two step (stupid!) so have decided to build the bottom end once and for all. For those that don't know, I was putting down 426/399 on 25 lb's of boost and E85 fuel. Its a shame I didn't get to make a pass on the stock bottom end at that power level. My best runs (with 80 hp / 60 ft/lb torque less) were 12.00 @ 121'ish. I would have been deep into the 11's on a stock bottom end. Oh well, I knew it was going to fail sooner or later with those numbers. I'm just depressed that I killed it on two step, bent cylinder 3 rod and cracked the wall. If you guys want big power, switch to E85, I was able to advance by timing 6 degrees (vs. my 93 octane tune) and still hadn't hit mean best torque (ran out of dyno time). The weak point is definitely the transmission once you start making big power numbers. I've gone through about 4-5 of them (3 before the quaife). I say 4-5 because it's hard to keep track lol. I ripped apart two stock differentials (they actually tore in half), destroyed the teeth on gear 3 and have experienced the tapered roller bearing cups grinding into the case causing excessive end play...
So now I'm finally going to install my Wiseco 8.8:1 pistons (had them for about a decade now), ordered up some Pauter rods and ARP hardware last week (thanks Jon for the info on the studs - old thread). Bottom line is I'm going to build it right and shoot for high numbers - looking to max out the GT3071R turbo (figuring 30-35 PSI will be its limit). Hoping to break the 500 whp mark which I think should be do-able, especially on E85.
Quick question, what fuel rail fits these intake manifolds? I was still running a stock rail with stock FPR believe it or not. I'm also going to have to do new injectors and fuel pump/line upgrades to supply the needed corn lol.
Look forward to more build info and information sharing, miss the RDTiburon days!
Regards,
Tyler
Old Apr 14, 2014 | 12:45 PM
  #129
hey glad to see you man! although i have no idea why you posted all that in jongtrs build thread lol
Old Apr 14, 2014 | 03:40 PM
  #130
XGODZX's Avatar
Vehicle: 1999 Elantra GLS Sportswagon
I've been told E85 needs 30% more so fuel pump, rail, lines and injectors need to be 30% greater ?
