How Do You Put On A Radiator Support?
Old Jun 11, 2008 | 04:33 PM
  #21
BLK2KTIB's Avatar
When I replaced mine I had to have a shop do it due to all the welds.
This is where i got it from
www.crosscanadaparts.com
part# 318649-0
Alot of Autoparts store deal with these guys.
Old Jun 11, 2008 | 06:48 PM
  #22
MOLOTOVMAN's Avatar
I have done 3, i currently did one on a mustang 2 days ago. BRB GONNA TAKE PICS......
all you need is a pop-rivet tool, a drill, and some JB cold weld,
EDIT: CAMERA NEEDS BATTERIES if interested will have pics tomorrow
Old Jun 11, 2008 | 07:00 PM
  #23
I'm not really sure if that would be considered ghetto rigging or not. Can I get confirmation on this technique? I can do that easily.
Old Jun 11, 2008 | 07:08 PM
  #24
MOLOTOVMAN's Avatar
has worked well for me, i have done it on a 99 cadillac deville, 01 mustang, and 04 elantra, or you can spend big bux on shop
BEFORE:
AFTER:
AND THE SHOP DID NOT TOUCH THE CAR
Old Jun 11, 2008 | 07:25 PM
  #25
Hmmmm. It looks promissing. I do like the idea, but I would like to hear someone else's oppinion of using pop rivits and filling it with JB weld.
Old Jun 11, 2008 | 07:38 PM
  #26
Would be fine but it needs to be DEAD ON.
Old Jun 11, 2008 | 07:41 PM
  #27
why do people keep saying that? How hard is it to align? Should I mount the radiator first? My fenders arent' busted, so I've got to remove the fenders, cut away the old brace, bolt on the new brace to the two holes, then tack it up where it needs to go. Right?
Old Jun 11, 2008 | 07:46 PM
  #28
Tib001's Avatar
lol Seriously though why?
IMO I wouldn't do it. If it is supposed to be welded then weld it.
Old Jun 11, 2008 | 07:53 PM
  #29
00rdshark's Avatar
it wouldnt be all that bad you would have to tak of the fenders yes drill or cut out the spot welds with a grinder making sure not to cut into the metal below the top layer. this will take some time to do,then u will prolly have to drill new holes in the new peice for every one then just line it up which should be fairly easy since ur car is damaged much. personally i would never use the pop rivits and jb weld since its not going to be nearly as strong as welds and the core support is a pretty important structural part.
Old Jun 11, 2008 | 07:54 PM
  #30
i would do it that way.. would work just as good as long as you used a good amount of rivets and did it right. just because its meant to weld, doesn't mean its the only way..
you could do it this DIY way with rivets and JB weld and save yourself a TON of money and be able to say you did it yourself.
of course if you were able to weld, or knew someone that would do it for cheap to free, then do it that way.
but i would give a thumbs up to the DIY rivet/JB weld way.
