Atelier HP
Sponsor:   Atelier HP
If you can think about it, they can make it for your Hyundai!
http://www.atelierhp.com/ = French (Canada)
http://www.atelierhp.com = English
Push Clutch Conversion
Old Jul 23, 2009 | 11:07 PM
  #71
Denisst99's Avatar
I've been UBER busy for the last weeks, that's the reason for the lack of update
engine and trans are i nthe car since last week end,hopefully i'll be able to run it soon and see if everything is working out like planned
Red, not better or worst then a stock dsm flywheel the pressure plate doesn't make full contact with the flywheel in stock form smile.gif
Dave,the dsm non turbo stuff will bolt on the beta flywheel and will work with our existing push conversion,no extra work needed
the reason behind the 225mm push conversion, is to get even more clamping power without the need for very agressive pressure palte and discs
Old Jul 24, 2009 | 08:07 AM
  #72
Perfect! Let us know how it goes. So you have it setup on stock flywheel with turbo DSM clutch then right? Thats exactly how mine will be so thats great. Keep us posted!
Old Jul 31, 2009 | 01:07 PM
  #73
David Dickson's Avatar
updates? lol....
Old Aug 3, 2009 | 04:00 PM
  #74
Denisst99's Avatar
waiting for the axles to show up and do real testing if the release point is right on
Old Aug 26, 2009 | 05:49 PM
  #75
Hey man, been working on this? Any updates? Thanks much
Old Sep 2, 2009 | 11:50 AM
  #76
Denisst99's Avatar
been working on my car when i have time wich is rare these days,
so far i did some pre-tests,might looks like our hydraulic system doesn't like the 2700 lbs pp i'm using..
car should be in working condition before the end of the month,so i'll have real update soon
btw, sorry for the wait guys,i'm just busy like hell over here,and my car is the first to suffer...
Old Sep 11, 2009 | 08:46 AM
  #77
are you using the Accent or Tiburon slave cylinder?
Old Sep 11, 2009 | 11:07 AM
  #78
Awesome. Im ready to buy as I have everything else I need to get the car back together. Cant wait man!
Old Sep 17, 2009 | 11:40 PM
  #79
Denisst99's Avatar
accent master (same bore then a tiburon master) and tiburon slave
i`ll get the truth very soon, so far i've got tru all the fab work on my car,nothing under the hood could be considered stock anymore (even if lots of the work isn't obvious to the untrained eye ;-)
I`ve got a bit of wiring,hook up the fuel system and it should be cranking after that
i`ve got a few details tha ti`ll make or work out over the winter, but i just want to drive it before the snow comes over...
Old Sep 18, 2009 | 11:15 AM
  #80
You think youll be able to put a couple of these kits together when you get it running?
