after some searching i came across someone able to get me the required parts to do do the push style conversion
this let you use a push clutch from mitsubishi either turbo or no turbo (turbo clutch will need some work on the flywheel but the non turbo will bolt right up act has a non turbo model that can hold about 475lbs/ft of torque i already got a complete kit,shouldn't take more then a few days to get other parts required lever, fork, retainer, bearing, 2 bushings this makes it a bolt on job,nothing to grind,nothing to modify,nothing to swear at i should be getting fixed pricing in the beginning of the week |
PLease, please, PLEASE list all parts and a simple DIY writeup. I dont need pictures I can figure it out. Thank you.
Sweet!
I guess I will see how my CM stage IV holds up and decide if I have to do this! Thanks. |
parts are all listed allready ;-)
FYI i don't have any part numbers,but did came across a dealer in my area wih enough patience and experience to try to find everything i needed for the how too it's actually VERY simple remove the trans, remove the stock clutch, remove the stock clutch fork,lever,retainer,bearing and bushings move the clutch cylinder to the other hole (the one that isn't used) install the new retainer install the new fork and pivot bushings install new clutch bearing install new lever install push style non turbo clutch of your choice on your actual flywheel reinstall transmission bleed hydraulic system bam you're done |
K denis, I hate you. After I already tore apart the tranny, bought new flywheel/act clutch, reassembled, now your making me tear it apart again.... mad.gif
Maybe I'll wait till this one blows up lmao.gif |
denis, this is great news. my new engine is going to be assembled and installed next week, but i'll ask them to wait so they can do the clutch conversion too. is there a clutch that you'd suggest for the conversion (300 whp/torque max). many thanks hail.gif
Looking forward to a thurough DIY on this with part numbers and some suggestions on clutches/flywheels. I'd love to find something I can get in the US, instead of dealing with these Korean companies that never ship.
i'm getting those from a local dealer, so no problem getting them
What year Mitsubishi are you working off of? I also assume its an eclipse? I know they probably have interchangeable parts between cars as well but for the sake of looking stuff up online.
Thanks! |
when i broke a PP bolt in my flywheel i went to dealer and they gave me evo8 PP bolts. so i know its all really similar
