plus, you could have traction issues spraying in first.
but waiting until 4k is a little much. |
ok, but with which shot are we talking about? 50 or 75? or it does´t matter?
my car seems to make more power ( nice power ) until 3000 rpms in first. I guess i have to test evrything you said, to know what you are trying to say, right? LOL in a manual tranny how can be use the nitrous, from what rpms? |
Shot doesn't really matter. I think if you have a window switch you will be safe to spray in 1st after 3500rpms or so.
In manual tranny I'd spray as soon as I shift into second. |
i think i would personally spray right after first, first doesn't seem like it's that long .... next time your at the track just try both, see what gives you the best/most consistent times. i think spraying in first will give you traction problems though, and what hamhead said is probably true also.
I was looking for that switch, but until now I could find it. but I also was thinking that what IF i install my activation switch in some butom near to me, and I press it and before I hit the rev limiter I depress the butom and when the car shift to 2nd gear i press it again?
could I do this? or could be results some damage because of this? |
You can find that switch at the place where you will be gettint your kit.
You can press it on and off, but I would just release gas for a second right before red line, until you shift into second and then floor it again. |
^^o´right, but maybe I going to buy from some friend, and he does not have the window swtich, maybe i will try to find it in some local shop from here, but i´m not sure.
and could I use nitrous every 2 minutes with 15sec of spray? I want to compete at the track but if is safe to use the nitrous that often. |
Shop around. You will find it!
At the track it will be used about 12-13 secs at a time and you will get more than 2 minutes off, so you are good to go. |
well..... finaly! i got my nitrous kit!...
i want to install this weekend, but i´m not sure if I can, so i´m going to have a 50 shot!. i dont have the windows switch yet. so? do I really need to get spark plugs one step colder ? and i´m going to use some additive to clean my inyectors, i have a new fuel filter, what else do I need? do I make another topic? |
Plugs are a must! Don't be cheap, they are only $3 a piece.
