Hi guys, I just want to know a little more of this kind of systems.
I was thinkg to install a system in my car, but I dont know what kind of modification are needed to run safety in a almost stock tiburon. What is the best and the safest brand of this systems? what is the biggest shot I can use in my car, with what mods and for how long it can be use? I know that the safety system is the DRY system, but am I right? sorry if there is a lot of quetions, I just want to know everything before make a decision. anyone has a system install? how do you installed it? pics? :blush: thanks laugh.gif |
<div class='quotetop'>QUOTE (sharkev @ May 3 2005, 09:10 AM)</div><div class='quotemain'>Hi guys, I just want to know a little more of this kind of systems.
I was thinkg to install a system in my car, but I dont know what kind of modification are needed to run safety in a almost stock tiburon.</div> If you not gonna exceed 50 shot then you will be safe with bone stock car. <div class='quotetop'>QUOTE </div><div class='quotemain'>What is the best and the safest brand of this systems?</div> NX wet kit <div class='quotetop'>QUOTE </div><div class='quotemain'>what is the biggest shot I can use in my car, with what mods and for how long it can be use?</div> Stock 50 shot, upgrde fuel pump and you can have up to 90 shot. Don't forget about colder spark plugs and highest octane fuel you can get. <div class='quotetop'>QUOTE </div><div class='quotemain'>I know that the safety system is the DRY system, but am I right?</div> Dry system is just another type of nitrous system, and I do not recommend getting one. Stick with wet kit. <div class='quotetop'>QUOTE </div><div class='quotemain'>anyone has a system install? how do you installed it? pics? :blush:</div> Check that link that Dweet gave you. |
If you're going to run nitrous (even just a 50 shot) at least get the following (small) mods, just to be safe--they're good to have anyway and are cheap:
new spark plugs (ngk's), 255lph fuel pump (walbro), and (like OP said) always fill with the highest octane fuel you can get and/or buy some Octane Booster http://www.nitrousexpress.com, get a WET NX kit. I would reccommend getting the mods listed above, a WET NX kit, and using a 50 shot. you could go higher, but i would not do more than a 90 shot(again, like OP said) |
You also need a gauge and bottle warmer (NX Gen II upgrade)... especially when you start using larger shots and need to have the kit running properly at the right PSI.
<span style="color:purple">what everyone said is true and to add my .02...nitrous express is the best kit imo to get. </span> smile.gif
ohh ok. thanks, but can anyone tell me WHY is the WET system the safest?
how much time can I use this system, and how much time do I have to wait to use it again? and I saw in dweet DIY install that the system only going to work at WOT, right? Is this the best way to install it? or is better to install with a bottom in the driver side? sorry about so many question but, its pretty expensive here, i have to know evrything before.. thanks how much for the 255lph walbro fuel pump? and Dweet, do you have a pic where and how do you put the bottle? |
how much time can I use this system, and how much time do I have to wait to use it again? and I saw in dweet DIY install that the system only going to work at WOT, right? Is this the best way to install it? [quote]or is better to install with a bottom in the driver side?[/quote[ <span style="color:red">huh?</span> how much for the 255lph walbro fuel pump? Btw, 255lph pump is too big. Use 190lph.</span> and Dweet, do you have a pic where and how do you put the bottle? |
A better pump does not mean necessarily more fuel flow. The FPR is probably the major restriction in the fuel system for the Tib. I would rather get one of those to bump up the PSI when the nitrous is activated, much like how a dry kit works.
With a new FPR and stock fuel pump you won't be able to raise the pressure that much man.... you will need a bigger pump!
And if your pressure will always be high, you will be always rich and will be wasting lots of gas rolleyes.gif |
