no clutch
Old Apr 20, 2018 | 07:45 PM
If brakes are sticking, then you might have to feather the clutch a lot more to get going. That will put a lot (a lot a lot) more heat into the clutch, and heat is what turns clutches into loose bundles of fiber in the bellhousing.
Rockauto is always a good place to buy parts, if you can wait on them and if they have them. Otherwise the parts stores will have all about the same quality of parts but I prefer Advance Auto Parts or O'reilley's.
Old Apr 21, 2018 | 11:13 AM
svaccent's Avatar
Vehicle: 2001 accent L 1.5l
thanks stocker... going to do autozone because of ergency-warranty-local. another new clutch set/both front calipers/both front break lines. during rechearching it seems the right break line is slightly longer than the left, does this seem correct.
Old Apr 23, 2018 | 06:46 PM
As long as it's within reason I wouldn't worry about slight variations in length. On a foot-ish hose, an inch or even two of length difference would seem strange but wouldn't bother me if everything fits well enough to not cause interference with other parts. A fraction of an inch I wouldn't think much about.
Old Apr 29, 2018 | 03:59 PM
svaccent's Avatar
ok got car back 4/27. replaced both front calipers-break lines-another clutch. my kid texts me "dad this car sucks", so whats wrong now. says feels like breaks dragging, car barely wants to do 40 mph. is there an issue with master cylinder??? we haven't replaced it. (what is this mod I heard about). THANKYOU FOR ANY HELP YA"LL CAN GIVE.
Old May 1, 2018 | 06:51 PM
When I swapped to manual transmission I didn't adjust the brake pedal and that's exactly what it felt like until I adjusted it. If you took delivery of a car in that shape, take it straight back to the mechanic.
The slave cylinder for the clutch has a restrictor that makes the clutch operate a little slower (at least, it did on my car). Pulling that out un-stupids the clutch pedal. Maybe that's what you are thinking of?
Old Jun 17, 2018 | 05:24 PM
svaccent's Avatar
stocker is there an image of this restrictor..or is it more or less self explanatory, if I take it apart..OH and apparently the car seems to be revving high again
Old Jun 18, 2018 | 08:27 PM
Basically this: https://www.evolutionm.net/forums/ev...ill-out-2.html
it's pretty similar, a small spring and a small plate with a hole in the middle, in the slave cylinder.
Did the car ever get fixed to where it actually worked right? If you kept driving around with dragging brakes, you might have fried another clutch.
Related Topics
Thread
Forum
Replies
Last Post
Redliner
5
Jul 3, 2016 05:51 PM
mitchpei
Engine, Intake, Exhaust
7
Jan 12, 2009 07:16 PM
2uniq
5
Jul 29, 2005 11:23 PM
97tibby
5
Apr 20, 2005 08:10 PM
AllBlackTibby
11
Feb 5, 2003 09:27 PM
