no clutch
2001 accent L 1.5l, replaced clutch with rockauto impact kit 2 months ago.was shifting to third heard a grinding then high rev. now start let out pedal and can shift to all gears without pushing in pedal...any directional guidance would be helpful...thanks
Throw out bearing maybe?
Does the car move?
Originally Posted by Visionz
(Post 719502)
Originally Posted by Juanra
(Post 719510)
Does the car move?
You have to start by removing the transmission and inspecting the clutch.
Did you install the kit or did a transmission shop do it? Could also be a faulty kit you bought from Rock Auto. Not sure I would trust any clutch parts from them.
I have had one issue with a part from RockAuto and they fixed it in a hurry. Not trust clutch parts?
Based on what you are saying; I would go look at the hydro system. Did something come loose or fluid leak out - master or slave give up with odd timing? If it was a beta I would go with the throw out bearing slipped its snap ring, but I am 94ish % sure the 1.5 is a push type. |
the guy should have it apart by Friday 4/20. he's been backed up. hopefully will know then. will post results.
so got the call this morning,..upon removing the inspection cover, lots of fibers present and apparently left front break caliper sticking. so if one or more calipers are sticking, could this cause excessive strain on the new clutch.where would you all advise getting parts from. dealer aint happening not spending 400+ just for individual parts???
