2002 Hyundai Accent 1.3 12V to Beta 1 2.0 Coupe Swap ( wiring?)
Old Mar 14, 2012 | 03:58 PM
  #51
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
Update!
Anthony got me some schematics of the beta 1 he has and they are way different then the U.S. spec, So im starting over. I do have the beta 1 to LC Accent schematics finished so if anyone wants them to run there beta 1 on the right ecm in the LC Accent let me know.
I am in need of wiring schematics for the 1.3L 02 Accent (England specs) to compare to U.S. spec. If the Beta 1's were that different then I fear the LC will be as well. Anyone got any ideas where to get these?
Old Mar 15, 2012 | 12:29 AM
  #52
HotBlue02's Avatar
Ok Antonyr123 I am done with the ecm pin outs so here it is. I will first give you the wire number, size and color as it is on the Alpha harness, then the new number(beta ecm pin) size and color to mark it. Then a brief description of the function. I would suggest you have a system were the alpha wires have both the original pin # then the new pin # in case we need to make corrections and identify original wire numbers. I still have 2 pins that are undecided as im seeing a mistake on the U.K. accent schematics.
03 Accent 1.5L SOHC U.K. Spec converted to 98 Tiburon 2.0L
Pin) (Color/Size) (New Pin) (Color/Size) (Description)
1) DMTL *To be Determined 4 use*)
2) (1.25 W) ** (29) (1.25 W) Coil Signal, Cyl 2 + 3
3) (2.0 B) ** (2) (2.0 B) Ground
4) *Blank*
5) (1.25 G) ** (28) (1.25 L) Coil Signal, Cyl 1 + 4
6) (0.5 Gr/O) ** (53) (0.5 Y/B) Injector 2
7) (0.5 Br) ** (4) (0.5 G/Y) Injector 3
8) (0.3 Gr) **(43) (0.3 W) Engine RPM
9) *Automatic Only*
10) *Automatic Only*
11) *Will not use*
12) (0.5 O/B) ** (32) (1.25 W/R) Memory Power
13) (0.5 B) ** (24) (1.25 B/W) On,Start Input
14) (0.5 Gr/O)** (48) (0.5 B/G) Engine Relay Control (combine with Accent pin 70)
15) (0.5 Br) ** (33) (0.5 W/L) Crank Sensor "A"
16) (0.5 Gr) ** (19) (0.5 W) Throttle Position Sensor Signal
17) (0.5 G) ** (46) (0.5 B/Y) Throttle Position Sensor Ground (combine with Accent pin 35)
18) (0.5 G/B) ** (17) (0.5 L/Y) O2 Sensor Upstream Signal
19) (0.5 O) ** (8) (0.5 L/R) Knock Sensor Signal
20) (0.5 L) ** (44) (0.5 Br/G) Knock Sensor Ground
21) * Will Not Use*
22) *Automatic Only*
23) *Blank*
24) *A/C Will Not Use*
25) *DMTL To be Determined 4 Use*
26) (0.5 Y) ** (54) (0.5 B/L) Idle Speed Actuator Closed
27) (0.5 Br/B) ** (30) (0.5 G/Y) Injector 1
28) *02 Sensor Downstream Not Used*
29) (0.5 Br) ** (26) (0.85 W/B) Idle Speed Actuator open
30) *DMTL To be Determined 4 Use*
31) (0.3 W) ** (47) (0.3 Y/L) CEL
32) (0.5 G) ** (45) (0.5 W/B) Throttle Position Sensor 5V Power (combine with Accent pin 33)
33) (0.5 L/O) ** (45) (0.5 W/B) MAP 5v (combine with Accent pin 32)
34) (0.3 W) ** (34) (0.5 Br/W) Crank Sensor "B"
35) (0.5 B) ** (46) (0.5 B/Y) Engine Coolant Temp Sensor Ground (combine with Accent pin 17)
36) (0.5 Y/O)** (18) (0.5 L) O2 Sensor Upstream Ground
37) (0.5 L) ** (16) (0.5 Gr/R) MAP Signal
38) *Blank*
39) (0.3 P) ** (15) (0.5 Y/R) Engine Coolant Temp Signal
40) *Blank*
41) *Blank*
42) (0.5 Y) ** (20) (0.5 Y) MAP, Incoming Air Temp
43) *Blank*
44) (0.5 P/B) ** (52) (1.25 R/W) Battery Voltage
45) (0.5 P/B) *Will Not Use* Battery Voltage
46) (0.5 L/O) ** (50) (0.5 R/B) Purge Control Valve
47) (0.5 Y/B( ** (25) (0.5 W/G) Injector 4
48) (0.5 Gr/B)** (55) (0.5 B) O2 Sensor "Heater"
49) (0.3 G/O) ** ( ) ( ) Immobilizer*Will Not Use*
50) (0.3 Gr) ** (13) (0.3 B/W) Condenser Fan Relay Control
51) (0.5 B) *Will Not Use* Ground
52) (0.5 Br) ** ( ) ( ) Immobilizer*Will Not Use*
53) (0.5 B) ** (31) (0.5 B)) Ground
54) *Blank*
55) *O2 Sensor Downstream Not Used*
56) *Blank*
57) *A/C Not Used*
58) *Blank*
59) (0.5 L/B) ** (12) (0.5 Y/W) Vehicle Speed Sensor
60) *Will Not Use*
61) (0.5 B) ** (3) (2.0 B) Ground
62) *Blank*
63) (0.5 P/B) *Will Not Use* Battery Voltage
64) *Blank*
65) *Blank*
66) *Blank*
67) *Blank*
68) (0.3 R) ** (23) (G/Br) Radiator Fan Relay Control
69) *A/C Will Not Use*
70) (0.5 G/B) ** (48) (0.5 B/G) Fuel Pump Relay Control (combine with Accent pin 14)
71) (0.3 R) ** (11) (0.3 L/Y) K-Line
72) *Automatic Only*
73) (0.5 P/B) *Will Not Use* Battery Voltage
74) (0.5 P/B) *Will Not Use* Battery Voltage
75) *A/C Will Not USE*
76) *Blank*
77) *Blank*
78) (0.5 B) *Will Not Use* Ground
79) (0.3 W/B) ** (42) (0.5 R) Camshaft Position Sensor Signal
80) (0.3 B) *Will Not Use* Ground
81) *Blank*
Still need to land the Smartra Immobilizer, other then that it is done.
Beta Harness: I found homes for every single wire on that harness except Pins 5, 6, 9, 38, 41, 51 = A/C, Automatic Trans and L-Line(diagnostic) fill those spots. L-Line can be ran direct to the OBD 2 plug. Pins: 1, 7, 10, 14, 22, 27, 35, 36, 37, 39, 40, 49 should all be blank. Pin 21 Is a Variable resistor and it needs looked into.
Old Mar 15, 2012 | 06:01 AM
  #53
wheel_of_steel's Avatar
Hotblue02 is the man. I'm dreadfully sorry, I forgot to get a photo of the smartra unit yesterday.
Old Mar 15, 2012 | 09:36 AM
  #54
HotBlue02's Avatar
No biggie, your reference pic was good enough. Ill be finishing up that pin out on the ecm after work.
Old Mar 15, 2012 | 06:48 PM
  #55
Antonyr123's Avatar
Vehicle: Hyundai Accent
That looks northing like the one my coupe or accent.
Its much smaller.
Old Mar 15, 2012 | 07:39 PM
  #56
Antonyr123's Avatar
Thanks hotblue, your a legend Mate.
Old Mar 15, 2012 | 10:52 PM
  #57
HotBlue02's Avatar
Updated ECM Pinout
Old Mar 16, 2012 | 01:55 PM
  #58
Antonyr123's Avatar
i sent u some opics of other stuff mate.
  #59
Antonyr123's Avatar
Old Mar 20, 2012 | 10:45 PM
  #60
HotBlue02's Avatar
Ok everything on the pin out is ready other then the possibility of you having the DMTL unit, it doesn't show up in the wiring.
Also the older style immobilizer on the beta does not interfere with the ecm, it went after the ECATS Module to prevent theft, so the immobilizer is eliminated from needing to be utilized.
