2002 Hyundai Accent 1.3 12V to Beta 1 2.0 Coupe Swap ( wiring?)
Old Mar 9, 2012 | 03:33 PM
  #41
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
I would imagine if the sensor is in the tumbler/ignition switch then you need the tib switch with key inserted and have it wired in so the immobilizer sees it and that signal runs to the ecm. This should allow you to use your normal ignition switch/ key with the tib one hidden somewere under the dash.
Old Mar 9, 2012 | 09:52 PM
  #42
Antonyr123's Avatar
Vehicle: Hyundai Accent
in uk we suffer them the sensor around the key failing alot causing the car to not start. As aslong as i stick the tib key fob by it permitly and fit a aftermarket alarm i should be ok.
Old Mar 9, 2012 | 10:31 PM
  #43
wheel_of_steel's Avatar
That is what I did, AUDM accents came with SMARTRA too. I've got the elantra key + transponder unit stuffed up inside my dash.
Old Mar 10, 2012 | 06:40 AM
  #44
Antonyr123's Avatar
well sadly me and blue found out its better to use the account loom and swap over all the sensors and ECM pins.
Old Mar 10, 2012 | 11:34 AM
  #45
HotBlue02's Avatar
Beta 1 harness is to different to attempt what I did to a Beta 2 harness on my swap, not that it couldnt get done, just way more work then we need to do. Sensor plugs that need changed are still to be determined, lets get the ECM side done first.
Old Mar 11, 2012 | 11:53 AM
  #46
Antonyr123's Avatar
Fair enuff Mate.
Old Mar 11, 2012 | 11:55 AM
  #47
Antonyr123's Avatar
do u have picture of where transponder unit is so i can maybe fit my accent.
i hope to god the accent and beta share the same connectors ect.
Old Mar 11, 2012 | 02:16 PM
  #48
HotBlue02's Avatar
love to see a pic of this smarta unit.
Old Mar 11, 2012 | 08:31 PM
  #49
Yep, I'll get you a photo on thursday, pinkie promise. The accent is back at my other house.
It is just a small transponder that clicks around the key barrel, here is a ghetto google image:
It is in the same place for both the elantra and the accent.
Old Mar 12, 2012 | 12:47 AM
  #50
HotBlue02's Avatar
Thats not what I was expecting, I will make sure the wiring is correct, you figure how to mount it.
