2002 Hyundai Accent 1.3 12V to Beta 1 2.0 Coupe Swap ( wiring?)
Old Feb 28, 2012 | 07:33 PM
Antonyr123's Avatar
Vehicle: Hyundai Accent
Default 2002 Hyundai Accent 1.3 12V to Beta 1 2.0 Coupe Swap ( wiring?)
Hey, I'm not to worryed about fiting.
I'm worryed about wiring.
My 1.3 is MAF and Beta dont seem to be.
can i swap the engine loom and keep accent dash loom unchanged ?
Old Feb 29, 2012 | 11:37 AM
Antonyr123's Avatar
2.0 engine loom plus..
Yellow Block, White Block and ECU Block
Old Feb 29, 2012 | 11:42 AM
Antonyr123's Avatar
any ideas if it plug right in 2002 LC
Old Feb 29, 2012 | 11:14 PM
HotBlue02's Avatar
Vehicle: 02 Hyundai Accent
The beta harness will not plug into your accent system without alot of hacking, been there done that. Its hard for me to say what you need to do as I have only dealt with the wiring on U.S. spec Hyundai's. So with that said here is what I did when i first beta swapped my 02 Accent back some time ago in 2004-05. The donar car was an 02 Elantra 2.0 beta 2 with manual transmission, ECM and engine harness, along with various other parts. now to the first harness.
1) Beta Harness - There are 2 connections coming off the engine harness that are behind the dash that tie into the body harness. Also I believe 2 plugs for the engine bay fuse box. On the alpha engine harness you will have the same situation for the most part, body harness connections and engine bay fuse box connections. What I did was cut off the connections (with enough wire left to solder) from the alpha harness and swapped them onto the Beta harness so that the Beta harness would plug and play. I made it sound Easy... IT WAS A PAIN IN THE ASS. You will end up having to reroute lots of wires and various other things.
2) A couple years ago this june I starved my engine of oil, so in went a new block. While the engine was out I picked up another 1.5L alpha harness for my car, removed the hacked beta harness and in went the alpha harness. I was able to repin the Alpha ECM plug to match the pinout of the Beta ECM. I also had to make a few changes under the hood in the way of the engine harness connections being rerouted and some of the plugs being repinned like I did at the ecm, just on a much smaller scale as the ecm had some 60 wires or so and every single one had to be moved.
There are many advantages to using your alpha harness over the beta harness
1) you only have to mess with the ecm plug and some of the sensor connections.
2) your not wasting money on another harness
3) You dont have to remove your existing harness... Pain in the ass.
4) Less work then then using the beta harness
Old Mar 1, 2012 | 12:48 PM
Antonyr123's Avatar
If i use my normal 1.3 12V harness. What will i need todo to it ?
Also do i need the 2.0 ECU and what about the Key & immboizer
I kinda got put off by the lack of active users for hyundai fourms. But i went for it knowing somone would help me and maybe peek more intrest in there lovely cars
Old Mar 1, 2012 | 01:01 PM
Antonyr123's Avatar
On my car. There are just 3 blocks behide dash.. white,yellow blocks & ecu pictured.
Am i now right in thinking i can just cut and rewire the sensors on alphas loom to the beta loom ? what do i do about ecu ?
Old Mar 1, 2012 | 10:21 PM
HotBlue02's Avatar
Repin the Accent ECM plug to match the beta ecm plug pinout and a few sensor plugs need repinned as well. Including repinning the maf sensor plug and making it map.
If the ecm you use has the immobilizer then grab them
You will find this sight has alot of traffic.
Old Mar 1, 2012 | 10:26 PM
HotBlue02's Avatar
I thought the pics were of the donor car, those are Accent pics?
We will get to that, what are the pics above from?
Old Mar 2, 2012 | 01:53 PM
Antonyr123's Avatar
The pictures above are of the beta Engine loom
Both Cars are immobilizered.
how am i suppose to know which pins i need to swap out?
The MAF & MAP sensors.. do i wire them over as they are.. pin 1 to pin 1 or what -confused.
i need pin layout of alpha ECM and Pin Layout of Beta ecm ?
Repin the Alpha ECM plug to match them of Beta and swap the ECU over ?
Old Mar 2, 2012 | 02:46 PM
Antonyr123's Avatar
Beta
1) sensor heating 0.5G/B (dmtl)
2) ignition coil "1" control 1.25L (cyl "2"3")
3) ignition ground 2.0B
4) *
5) ignition coil "2" control 1.25Br (cyl "1"4")
6) injector 2 control 0.5B/O
7) injector 3 control 0.5Br
8) engine rpm signal 0.3Gr
9) tps signal 0.3P
10) torque reduction signal (Automatic Only) 0.3W/B (tcm)
11) fuel consumption/injection signal (LC2 Only) 0.5L
12) memory power/battery voltage supply 0.5O/B
13) on/start input 0.5O
14) engine control relay control 0.5Gr/O
15) ground "A" (cps)0.3Br
16) sensor signal 0.5G (tps)
17) sensor ground 0.5G (tps, dlc, acs)
18) sensor signal0.5G/B (O2 sensor up)
19) sensor signal 0.5O (knock sensor)
20) sensor ground 0.5L (knock sensor)
21) fuel gauge 0.3G/B
22) mil request line (Automatic Only) 0.3Y/B (tcm)
23) *
24) cooling signal input 0.3Y/B
25) solenoid control 0.5P/B (dmtl)
26) close 0.5Y (isa)
27) injector 1 control 0.5Br/B
28) sensor heating 0.5O (O2 sensor down)
29) open 0.5Br (idle speed acuator)
30) pump control 0.5Y/B (diagnosis module for tank leakage)
31) check engine indicator control 0.3W (cel)
32) sensor power 5v 0.5G/B (tps)(acs)
33) sensor power (maf) 0.5R/O & sensor power (map) 0.5L/O
34) sensor power "B" 0.3W (cps)
35) sensor ground 0.5B (O2 sensor down, engine coolant temp sensor & sender)
36) sensor ground 0.5B (O2 sensor up, maf, map)
37) (maf)afs signal 0.5L () (map) map signal 0.5L
38) *
39) sensor signal 0.3P (ect)
40) *
41) *
42) (maf)ats signal 0.5Y () (map)iat signal 0.5Y
43) *
44) battery voltage 0.5P/B
45) battery voltage 0.5P/B
46) pvc control 0.5L/O
47) injector 4 control 0.5B/O
48) sensor heating 0.5Gr/B (O2 sensor up)
49) "immo" indicator control 0.5 G/O (not used)
50) fan relay control high 0.3Y
51) ground 0.5B
52) signal "smatra" 0.5Br (not used)
53) ground 0.5B
54) *
55) sensor signal 0.5G/O (O2 sensor down)
56) *
57) a/c signal input 0.3P
58) *
59) vehicle speed signal 0.3L/B (tcm)
60) sensor signal 0.3G/O (accelerator sensor)
61) ground 0.5B
62) *
63) battery voltage 0.5P/B
64) *
65) *
66) *
67) *
68) fan relay control low 0.3Y/B
69) a/c relay control 0.5Br
70) feul pump control relay 0.5G/B
71) k-line 0.3R (tcm, dlc)
72) torque reduction request 0.3O (tcm)
73) (m/t) battery voltage 0.5P/B () (a/t) drive position switch "D"2"L" 0.3P/B
74) (m/t) battery voltage 0.5R () (a/t) drive position switch "R" 0.5R
75) a/c switch "on" input 0.5P
76) *
77) *
78) ground, MT/AT Encoding (Automatic Only) 0.5B
79) sensor signal 0.3W/B (cmp)
80) ground 0.3B
81) *
alhpa
1 Fuel pump Relay Control
2 Idle Speed Control actuator (Closeing)
3 Injector (cylinder 1)
4 Injector (cylinder 3)
5 Unused
6 Ground
7 Unused
8 Malfunction Indicator Lamp control
9 Unused
10 Unused
11 Rear oxygen sensor Ground
12 Front oxygen sensor Ground
13 Unused
14 Mass Air Flow Sensor Ground (-)
15 Unused
16 Crankshaft posistion sensor A
17 Unused
18 Canister Close Valve Control
19 Condenser Fan Relay Control
20 Unused
21 Unused
22 Unused
23 Unused
24 Unused
25 Ignition Coil Control
26 Memory Power
27 Engine Relay Control
28 Ground
29 Idle Speed control actuator (opening)
30 Rear oxygen sensor heating
31 Injector (cylinder 3)
32 Injector (cylinder 2)
33 Unused
34 Ground
35 unused
36 Canister purge control valve
37 Front oxygen sensor heating
38 TSP Output (tcm)
39 Rear Oxygen sensor
40 Front oxygen sensor ground
41 Mass air flow sensor fround (-)
42 Vehicle speed input
43 Crankshaft posistion sensor B
44 camshaft postition sensor signal
45 radiator fan relay control
46 Unused
47 engine speed output
48 A/C relay control
49 Unused
50 Unused
51 Unused
52 Ignition Coil Control
53 Unused
54 Battery Voltage
55 Ground
56 Unused
57 Unused
58 Start/On Imput
59 +5v Supply
60 Reprogramming Line
61 Mil Request Line (ecm-tcm)
62 Unused
63 Unused
64 A/C switch "on" input
65 A/C thermostatic and pressure input
66 Unused
67 Unused
68 unused
69 Unused
70 Knock Sensor signal
71 Sensor Ground
72 Switch for characteristic map
73 Throttle posistion sensor signal
74 Unused
75 Unused
76 fuel Tank pressure sensor signal
77 Air temperature sensor input
78 Engine coolant temperature input
79 Unused
80 Acceleration sensor
81 Unused
82 Diagnosis L-Line
83 Diagnosis K-Line
84 Unused
85 Torgue reduction signal
86 Drive posistion Switch (M/T: Open) (A/T/N Close,D-Open)
