My Very Own Exhaust Build
Old Apr 28, 2009 | 09:39 AM
you're right about the 2 things. those O2's can even detect a bad cat. the reason ebay cats are so cheap compared to $800 factory are because the ebay ones are less restrictive and have next to no carbon filtration so the O2's detect this. O2 fouler will fix this. same goes for no cat/test pipe.
if you've extended the wires, make sure the connections are solid (which i know you did) and all the wires match up. it's the two white wires that confused me. it took 2 years for me to finally get mine identified with the help of bullfrog and DTN, we finally fixed it.
my first guess would be the lack of catalytic. i'd never recommend anyone to take it out after what i've been through.
Old Apr 28, 2009 | 09:40 AM
Bullfrog's Avatar
Vehicle: 2001 Tiburon
One code is for bad wiring, The 2nd code is that if you have both o2 sensors reading the same value before and after the cat... 2nd o2 sensor is to make sure the cat is working ok.
Old Apr 28, 2009 | 11:28 AM
also Sean you need to state if your tib came with 2 cats seeing its an 01...one on manifold and one under the car...
i gurantee it did and i told you what i would do on AIM this morning
Old Apr 28, 2009 | 12:15 PM
hamhead's Avatar
Jegs is good.
How thick was the pipe you bought ursonvs? Saw you bought OD 2.5 pipe, but ID 2.5 on the other pieces.
Old Apr 28, 2009 | 03:10 PM
UrS0NvS's Avatar
2.5" i.d. ham on the pipe. my car has a apexi catback but i bought the pipe and made a under axle exhaust for the gf's car.
Old Apr 28, 2009 | 03:13 PM
Hyunshark21's Avatar
So doing something along the lines of this will help me with the code?
http://forums.evolutionm.net/evo-how-reque...-cel-light.html
and i do it to the second o2 sensor just like the DIY?
Old Apr 28, 2009 | 04:22 PM
hamhead's Avatar
Probably so.
Old May 29, 2010 | 12:45 AM
Im digging this thread out
Today i received all the parts for my custom exhaust. I cant wait till i install it.
Exhaust Includes:
-28" Thrush GlassPack
-16"Dynomax Resonator
-Magnaflow Cat Converter
-Dynomax Super Turbo Muffler
-Magnaflow Tip
-Mandrel bent 2.5" piping
Ordered from summit racing, took 2 days to ship, ended up paying 350 total. Installation will be free because it will be done by yours truly (with the help of pops)
Yes a beer can, can (what?) fit in my exhaust
Still am undecided whether im going over or under rear axle. Leaning towards under. Also will be painting exhaust to slow down rust.
Old May 30, 2010 | 10:46 AM
Bullfrog's Avatar
looking good. Make sure to paint it with weld tru primer. It can withstand he heat better then the duplicolor ceramic paint. It will cut the rust as well.
Old May 30, 2010 | 01:04 PM
iheartmyrd's Avatar
Vehicle: 1998 Hyundai Tiburon
Unless your are unable to make it over axle that would be the only reason i would advise not to, because your not going to see any real gain from going under axle.
just my 2cents
