My Engine
Old Sep 17, 2007 | 03:17 PM
  #31
Hyundai4g63T's Avatar
Vehicle: Had 96 Elantra Wagon
If it does turn out to be a HLA, soak them in ATF and that will eat up the oil residue in them
Old Sep 17, 2007 | 03:37 PM
  #32
deestibo's Avatar
that shouldsove it?
I think im about to get out of the hyunai scene and part my whole car out.
This shit doesnt stop for past 6years i had the dam thing.
Old Sep 17, 2007 | 03:42 PM
  #33
01steve's Avatar
Vehicle: 2000 hyundai tiburon
my car recently started doing this as well (i'm n/a)-... i did some searching and realized it might be my oil FILTER. i haven't changed the oil since this info surfaced but i'm switching to hyundai OEM next time.
there is a hyundai tsb on it. apparently, it's pretty common.
good luck!
Old Sep 17, 2007 | 03:58 PM
  #34
deestibo's Avatar
its not coming from or near oil filter or pan,coming from the block or camshaft area.
Old Sep 17, 2007 | 04:10 PM
  #35
Zman's Avatar
QUOTE (deestibo @ Sep 17 2007, 04:37 PM)
that shouldsove it?
Don't decide just yet, it's better to cool off and then think what you will do; sh!t happens you know, and if it's your HLAs, only thing I can comment is we all have been there sometime...
HLAs are not expensive nor expensive to change, and if it's that and you fix it, you will be very happy with your car again.
Old Sep 17, 2007 | 04:34 PM
  #36
ScoupeLS's Avatar
Vehicle: 2003 Tiburón GT
it may be bent valves. that compression test numbers are too low. i remember that my scoupe turbo had 7.5:1 pistons and it was around 150psi on each cylinder. just my 2 cents
Old Sep 17, 2007 | 05:52 PM
  #37
deestibo's Avatar
Ok taht compression check was probaly wrong cause i didnt do it right.
Do you think it could be knock sensor or cam sensor?
Ok how can you tell if it is hla without riping all apart?
book said push on them and if they go down there bad well all of them go down a little so thats like $275
for all of them,cause dealer $17 a piece.really not worth it my well get another engine and thro my pistons in it or swap it from engine.
Old Sep 17, 2007 | 06:26 PM
  #38
Zman's Avatar
Ask for a quote for a HLA set on SFR, I got mine from kspec back in the day, and it was waaaaay less expensive than your dealer has quoted you.
Old Sep 17, 2007 | 06:29 PM
  #39
deestibo's Avatar
i would but sfr would probaly take months to get,there shipping is horrible from what i read always takes mad long.
I want this car to get fixed quick so ill way my options and see.
Might just start parting out everything.Its lways something new fix one thing whole another pops up.
Might just wait for the new tibs come out ge one of those,and take the lose on this car.
Old Sep 17, 2007 | 07:23 PM
  #40
cheesebox's Avatar
If you tear her apart to fix I can make my way over their and help you out bro. Projects like that suck scrote alone. Ill use my whole year of auto-school experience laugh.gif *Cough* turn a wrench
