DIY clutch installation
Old Apr 6, 2005 | 12:05 AM
shadowcat357's Avatar
<div class='quotetop'>QUOTE (01roller @ Mar 25 2005, 08:30 PM)</div><div class='quotemain'>this diy is good, it just left out the part about....... take the clutch lever (connects to clutch release cylinder) off of the fork before you try to pull off the tranny..........
Took me a while to get the tranny out the first time because I didn't do that. VERY IMPORTANT.
Also be sure to get that throut bearing in there properly the first time. Unlike me 02.gif
Old Apr 6, 2005 | 04:28 PM
01roller's Avatar
<div class='quotetop'>QUOTE (shadowcat357 @ Apr 6 2005, 06:05 AM)</div><div class='quotemain'>Took me a while to get the tranny out the first time because I didn't do that. VERY IMPORTANT.
o yes, shouldve said that before also, i did that too.....
be sure <u>not</u> to place the throwout bearing into the clutch..... slide it onto the fork and then reattach the tranny.
Old May 13, 2006 | 12:14 PM
Alex01tib's Avatar
Any body have any tips for removing the tie rod? I read the DIY from skitso and after you remove the cotter pin and the nut it says to pound the tie rod with a hammer or pry it off the mount. Niether worked. Dont know what else could be done to get this damn thing off
Any personal experiance would be greatly appreciated.
Old May 13, 2006 | 12:32 PM
landshark16's Avatar
If you have a pickle fork you can wedge it in there and pry on it. Thats how I did it...twice....lol.
Old May 13, 2006 | 01:41 PM
Alex01tib's Avatar
Thanks but i called viper966 and told me to take the 2bolts off the strut tower and then remove the drive shaft, we did and it was tons easier. and we didnt have to mess with the tie rod
Old May 13, 2006 | 01:43 PM
Thats cool. Ill remember that for future reference.
Old May 13, 2006 | 03:37 PM
fonseca's Avatar
We should have a comprehensive DIY here that includes these different steps and tips
Old May 14, 2006 | 12:02 AM
Alex01tib's Avatar
finally dropped the tranny with some help from brian again.
Now im trying to figure out how to get the clutch pressure plate and throwout bearing out. In the DIY he says undo the bolts and pry it off, and I undid the bolts and there is no real place to pry from... Tried a couple spots and it did nothing...
Old May 15, 2006 | 02:57 AM
Alex01tib's Avatar
Nevermind i didnt know the release bearing didnt have to be removed before the pressure plate could be removed. Brain to the rescue again.
I put my chromoly flywheel in with my stage 3 clutch, looks and fits great
Now im just having trouble mounting the tranny back on, suckers being a stubborn bastard. We got the top two bolts of the bell housing in but the bottom didnt want to go on, were thinking the tranny has to be perfectly level when sliding the tranny in, so tomarrow im importing another set of hands and possibly a engine hoist to hold the tranny while we guide the bolts in place.
Old May 15, 2006 | 01:25 PM
SwiftTiburon's Avatar
^^Damn, went to bed a little late today huh? lol 5 am..
