DIY clutch installation
Old Aug 7, 2004 | 12:44 PM
01roller's Avatar
Default Re: Went to the track again :)
DIY clutch install
http://www.hyundaiaftermarket.com/download.../clutch_diy.doc
found this on HA.com
its missing a few steps .... pm me if you wanna know
Old Dec 17, 2004 | 11:35 AM
a_gut's Avatar
Default Re: Best Cheap OEM Mod Yet... *Teaser*
I tried searching for this file and couldn't find it. Does anyone have it saved? I'm installing my VHR clutch within the next week and it would really help laugh.gif . Also, any tips for installing that may not be in the diy?
Edit: found the diy in one of the engine&transmission threads... http://www.rdtiburon.com/index.php?name=Fo...viewtopic&t=636
Old Dec 17, 2004 | 05:43 PM
Default Re: Help! I can take out key from ignition while i'm on &
Email Blacktibs, he has a whole DL of Hyundaiaftermarket.
Random may have it too.
Old Mar 20, 2005 | 05:35 PM
FlyRyde's Avatar
I have an image archive, nothing else. Hit up Random if you need to know anything regarding oldschool HA threads. He's the magic man for that.
Hit me up if you need a pic, but only if you really really need it, and I'll search the endless depths of pics Random had on his hard drive.
Old Mar 21, 2005 | 11:24 AM
Jaws021's Avatar
i have a butt load of pics from his hard drive as well...
Ill also be doing a clutch install myself within the next week or two
If you need anything let me know..
Old Mar 21, 2005 | 12:45 PM
alz99's Avatar
Vehicle: FX Coupe
send me over an email i have it.
Old Mar 24, 2005 | 12:45 PM
Skitzo's Avatar
If somebody wants to send it to me, I can keep it online for everyone and link it into this forum again.
Old Mar 25, 2005 | 01:30 PM
01roller's Avatar
speedracer on hp reuploaded it.....
<span style="color:#004a83">http://www.thegraphixlab.com/Curt/clutch_diy.doc</span>
this diy is good, it just left out the part about....... take the clutch lever (connects to clutch release cylinder) off of the fork before you try to pull off the tranny..........
Old Mar 28, 2005 | 09:08 AM
Skitzo's Avatar
I might as well put it up too. Always good to have a backup....plus I'll convert it to PDF. Should take it way below 2mb.
http://www.burningland.com/images/clutch_diy.pdf
Old Mar 28, 2005 | 09:27 PM
Viper966's Avatar
fyi to remove the axels u can just pull the two bolts that hold the strut to the spindle and than knock the axel back through the spindle and u can take it out without undoing the ball joint
