Perfect Power Smt-6 Wiring Diagrams Guide
Old Dec 26, 2006 | 09:21 PM
  #31
shimanomtber87's Avatar
From: York. About 2hrs from Philly and 4 hours from Pittsburgh
Just installed an smt 6 with a 99 tib. For everyone with a 97-99 car the ecu wire colors for the basic setup should be as follows:
Pin 55- black
Pin58- black w/ white stripe
pin 73- white
pin 41- white w/ yellow stripe
pin 47- white
Old Mar 24, 2007 | 11:57 AM
  #32
Jay-M's Avatar
Vehicle: 01 Tiburon
UPDATE:
Thanks to nate704...
This is how denis' turbo box version 2 is connected! This wiring diagram also shows the secondary injectors' connections
Old Mar 24, 2007 | 01:34 PM
  #33
tanc's Avatar
Vehicle: 1997 Tiburon
Very nice, I needed that.
Old Aug 16, 2007 | 03:19 PM
  #34
balbains324's Avatar
Vehicle: 1998 Hyundai Coupe
Guys I have a map sensor based car from the UK and want to know if I just need to replace the MAFS analogue in with the Map analogue in?
Old Aug 16, 2007 | 03:37 PM
  #35
Jay-M's Avatar
Vehicle: 01 Tiburon
right-o!!!
MAF and MAP Sensors uses the 0-5 volt "rule"
Old Aug 22, 2007 | 08:52 PM
  #36
Denisst99's Avatar
BAl
is your car obd1 or obd2
i think euro spec car still run obd1....
Old Aug 26, 2007 | 12:40 PM
  #37
Dennis
I think my car is OBD 1 because it only has two lines of wires for the ECU, unlike the US spec which has 3 lines of wires for the ECU connection.
Old Aug 26, 2007 | 11:37 PM
  #38
NYelantraGuy's Avatar
This is exaclty what im using for my turbo....... SMT6, Tubro (black) Box, and a dual fuel rail all from Denis. these diagrams are awsome. i will be in contact with you when the time comes!
Old Aug 27, 2007 | 10:32 AM
  #39
Jay-M's Avatar
Vehicle: 01 Tiburon
NYelantraGUy,
The ECM pin outs for your 02 Elantra is different from the RD's. Here is something that can help you out. You might need to spend some time on the drawing board devising a wiring diagram if one is not available for your vehicle.
01-02 Elantra ECM Pinout
1) ground 2.0B
2) ground 2.0B
3) battery voltage 2.0L
4) ignition coil 1 control 0.5G (cyl 1, 4)
5) ignition coil 2 control 0.5Y (cyl 2, 3)
6) low voltage tcm 0.3Br
7) high voltage tcm 0.3W
8) O2 sensor up heating 0.5P
9) O2 sensor down heating 0.5P
10) kns sensor signal 0.5Br
11)
12)
13)
14) battery voltage 0.5W
15)
16)
17) wheel speed input 0.5O (right front wheel sensor w/out abs)
18) wheel speed input 0.5G (right front wheel sensor w/out abs)
19)
20)
21) battery voltage 0.5W
22) on/start input 0.5R
23) injector 4 control 0.5O
24) injector 1 control 0.5L
25)
26) cpv control 0.5Y/O
27) cps ground 0.5L/B
28)
29) cps signal 0.5G
30) cps & kns sensor ground 0.5Gr
31) ect input 0.5G/B
32) tps signal 0.5L/B
33) ftp signal 0.5G/O
34) ftp ground 0.5L/B
35)
36)
37)
38) tps ground 0.5R/B
39) vehicle speed input 0.3Gr/O (with abs)
40)
41)
42) O2 sensor down signal 0.5G
43) O2 sensor up signal 0.5G
44) sensor power 5v 0.5R (map, ftp)
45) tps power 0.5L
46)
47) immo signal 0.5L/B (not used in U.S. and not availible on 01 model)
48) map sensor ground 0.5G
49)
50) a/c signal input 0.5Y
51) cooling signal input 0.5Br/O
52)
53)
54)
55) ground 0.5B
56) iat signal 0.5Gr(map)
57)
58) a/c switch "on" input 0.3Y/B
59) sensor ground 0.5B (O2 sensors and ect sensor)
60) map signal 0.5G
61) injector 3 control 0.5L/B
62) injector 2 control 0.5R/B
63)
64) fan relay control high 0.5Gr
65) fan relay control low 0.5Y/O
66) engine rpm signal 0.5L (cluster)
67) engine control relay control 0.5O
68) a/c relay control 0.5O
69) fuel pump relay control 0.5R/B
70) mil indicator control 0.3Br/O (cel)
71) immo ground 0.5B (not used in U.S. and not availible on 01 model)
72) cps sensor signal 0.5R/B
73)
74)
75) consumption 0.5L/O (micro controller in cluster)
76)
77) k-line 0.5G/B (dlc, tcm)
78) isa opening 0.5Gr
79) ccv control 0.5L/B
80) isa closing 0.5G
81)
Old Oct 19, 2007 | 08:21 PM
  #40
ok im going to cuba for a year in Jan and i have been putting together my turbo project and i got the smt 6 and turbo box from denis...i will be using the duel rail kit also...and i want to get as much down that i can do without putting on turbo...so here is my question...
Can i hook up the SMT 6/turbo box as per that lastest diagram that Nate704 produced...but without the duel rail kit?
