Perfect Power Smt-6 Wiring Diagrams Guide
Old Aug 31, 2006 | 07:37 AM
  #21
shimanomtber87's Avatar
From: York. About 2hrs from Philly and 4 hours from Pittsburgh
I'd like to get the guy at the dyno shop too tune the afr and timing. Should i just use the first diagram or the second?
Old Sep 9, 2006 | 08:53 AM
  #22
Jay-M's Avatar
Vehicle: 01 Tiburon
yes, use the 2nd diagram to be able to "play" with the timing
but mind you for low boost... adjusting the timing is not really necessary
i've run up to 8 psi on my setup without retarding the timing with no detonations... just made sure that delivering enough fuel with higher octane
Old Oct 15, 2006 | 02:17 AM
  #23
Alex01tib's Avatar
Ok i know this is late and my chances of getting someone who knows the SMT-6 intimately are slim. But i installed it and all i get when i click "go online" is
runtime error "6"
overflow
And then the Window shuts down.
I tried loading the map first, and i also tried setting the global settings, but as soon as i hit go online it says runtime error 6 and shuts down.
I wired it in like the diagram in this thread shows for the extra injectors. Im pretty darn confident in my wiring also.
Ill PM denis and jay tho.
Old Oct 15, 2006 | 06:07 AM
  #24
yamaha's Avatar
Vehicle: 2000 Hyundai Elantra
Something is screwed up on your SMT, did you try to do a reset?
Old Oct 15, 2006 | 10:22 AM
  #25
Jay-M's Avatar
Vehicle: 01 Tiburon
alex,
it looks like a communication problem between the smt-6 and your laptop... you need to FULLY uninstall the smt-6 software (control panel... add/remove programs thingamagig) then after reinstall it again... oh also, you might wanna visit the perfect power site and see if you are running the latest version of it if there is any changes
also, are you using your com port (rs232-c/serial cable) or the usb port with a usb to serial adapter? please check you comm settings on your laptop
let us know what the results... i will pm you my contact phone number wink1.gif
Old Oct 15, 2006 | 10:39 AM
  #26
Alex01tib's Avatar
You mean reset my SMT-6? if so no i didnt try that. How do i go about it properly?
Old Oct 17, 2006 | 09:32 AM
  #27
Jay-M's Avatar
Vehicle: 01 Tiburon
i believe that you dont have to reset your smt-6 on your current situation... but you could try that as well and see
update me more details on PM
Old Oct 19, 2006 | 03:02 PM
  #28
Alex01tib's Avatar
Guess i should update.
After talking to deniss on msn for like 2 days trying every little thing, swapping between my extra SMT-6 and using different comms cables, checking the wiring, and countless uninstall and reinstallations.
Deniss suggested i download the version he uses v2.6.7 (as opposed to 2.6.11) and try to reset the SMT-6.
It worked and i ended up staying up all night tuning my car to get about a 11.8-12.3 anytime i was under boost.
i managed to get up to 7 pounds and the car was pulling hard. I would have kept going but yesterday my "speed-factor special" turbo Fux0r3d on the way to work.
Time for a NEW bb t3/t4 CHRA. firedevil.gif
Old Oct 19, 2006 | 06:11 PM
  #29
'treezy's Avatar
Old Oct 20, 2006 | 03:08 PM
  #30
Alex01tib's Avatar
why? u noticed i said ball bearing chra right? and im getting it for something like $500.
