my new fuel pump
Old Jan 28, 2011 | 07:23 PM
steelcoffinx3's Avatar
Vehicle: 99 accent
If the stock ecu couldn't compensate it would throw a fuel trim rich code-it doesn't and as far as I could tell the off boost fuel curve was the same, same lean spot at low rpm. Maybe your pump setup flows more than mine (stock pump inline with the 255lph) idk.
Old Jan 28, 2011 | 07:31 PM
Turboron_99's Avatar
Vehicle: 13 Gen Coupe Ult.
Removed stock and replace with Walbro hi flow hi pressure 255! I have the same setup that AvanteKing is going for...
Old Jan 28, 2011 | 08:16 PM
iheartmyrd's Avatar
Vehicle: 1998 Hyundai Tiburon
It sounds like coffin has a booster.
Old Jan 28, 2011 | 08:38 PM
turbosocks's Avatar
i would strongly recommend waiting to install the pump until you get a RRFPR.
Old Jan 28, 2011 | 09:33 PM
AvanteKing's Avatar
Vehicle: 1998 Elantra
thats what i doing, i trust you guys im not stubborn i understand y its a bad idea to do what i askedlol, thnaks guys, and whats closed and open loop?
Old Jan 28, 2011 | 09:39 PM
turbosocks's Avatar
for the RRFPR, you will need a 3/8NPT tap for the rail (~18$) npt to AN fitting + some AN fittings + feed line + return line + fuel pressure gauge + 31/64 drill bit or a steady hand with a dremel
Old Jan 28, 2011 | 10:20 PM
Your cars ECU will operate in closed and open loop, open loop would be any time driving when not a WOT, closed loop comes on at WOT or cold starts. Just changes how the ECU regulates Fuel with pulse width.
Also ^^^^^ there is the guy that can hook you up with a FRP kit!!!
I dig mine, works well, and looks nice!!!
Old Jan 28, 2011 | 11:45 PM
AvanteKing's Avatar
bummer, tonight i installed my new oil pan and what not, guide told me to use rtv silicone and i did, well sure enuff there is a tiny leak );; now i gotta rip everything out and redo it, the pan came with a gasket but the guide told me to use rtv, should i just use a gasket? im kinda bummed right now and im going to take a break fr a few days cuz im pretty pisttt
Old Jan 29, 2011 | 08:37 AM
nos4atu's Avatar
Yes. Put a thin layer of rtv along the block,(use your finger to do this)place the gasket on, and a thin layer on the oil pan,(using the same finger technique.
Old Jan 29, 2011 | 11:33 AM
Vehicle: 99 accent
Closed loop happens at idle and light cruse where the afr fluctuates between rich and lean averaging 14.7:1, open loop is during acceleration and the ecu controls fuel based on the maf/iat sensor and rpm readings.
