Ericy's Turbo Build Pics
I wish man. The next hurdle is this clutch deal. I thought it was something more difficult but in a way the modification is a lot harder even though its simple. If that makes sense. We need to use a spacer to space the whole pressure plate out. I can make one no problem but dont know how thick to make it. Since I just want it to work I figure since Dennist already has a decent handle on it Ill wait for him to hopefully come out with a piece I can buy from him shortly.
act 2900 + puck disc?
mucho hardcore stuff...
i'd say 2900 + street disc or 2600 + puck disc)
i'm leaning toward a 2700 + street disc for mine (yup 2700)
The ARP head bolts should be torqued around 80ftlbs if I remember correctly. But ARP will gladly tell you with one phone call. I've heard of others breaking them. I can see 100ftlbs doing it, especially with their lube. You're supposed to let off 5-7lbs if using the lube.
Just got off the phone with them.
60ftlbs for the M10's and 80ftlbs for the M12's. This is with their lube, so I would go maybe 5lbs more using regular engine oil.
