Couple ?'s For Boosted Veterans.
Old Sep 27, 2005 | 04:44 PM
Your avatar has been broke for a few weeks.
Old Sep 27, 2005 | 05:04 PM
hamhead's Avatar
So you go WOT, boosting with black smoke, then when you shift it turns blue? Awesome. lmao.gif
Some cars I know when they shift there is a lil poof of smoke, and they run properly and fine every other way.
Old Sep 27, 2005 | 05:17 PM
Jaws021's Avatar
I am still not sure how you are routing the PCV valve..
T'd 5th hose?
As long as it is venting to the atmos.
As far leaking turbo oil seals.. one way is to check the charge piping. If there is oil, take the turbo back and have it replaced. Is your turbo used or new?
If its used.. thats probably what it is..
The black smoke comes from running rich... stop being a retard and go and tune it.. wink1.gif
Usually if your not pressurizing the crank case, and your still seeing blue smoke,... its the turbo.
Its either rebuild time(if its used) or replacement time (if its new).
Old Sep 27, 2005 | 06:47 PM
Thanks for fixing your avatar.
Old Sep 27, 2005 | 06:55 PM
hamhead's Avatar
Ye, generally if your seeing blue smoke... your seals may be going bad, or you might have debris buildup in there. Maybe the seals aren't bad enough to cause problems low boost, but at high they are too weak.
In any event, doesn't take too much time to tear it apart.
Old Sep 27, 2005 | 08:19 PM
yeah, thats definately not where you want it. there is a allen bolt on the very right side of the head. most people use that.
