Couple ?'s For Boosted Veterans.
Old Sep 28, 2005 | 04:51 PM
  #21
Denisst99's Avatar
did you check the play of the turbo shaft?
check the horizontal and vertical play
Old Sep 29, 2005 | 10:08 PM
  #23
Denisst99's Avatar
yeah but now. .how is the play?
busted seal ,loose bearing can also make the turbo leak from the outside a bit
usually oil seam to leak from between the exhaust housing and the center section
Old Sep 30, 2005 | 08:26 AM
  #25
Casper's Avatar
QUOTE (01importshark @ Sep 30 2005, 08:29 AM)
bahh.... figures that i get a bad turbo.... what luck..
I dont think you got a bad turbo, you just hooked up the oil feed line in the wrong place.... expensive lesson.
Old Sep 30, 2005 | 11:32 AM
  #26
hamhead's Avatar
But yeah, we all make mistakes... thats why we all say keep an extra $1000 around for after the turbo is installed. fing02.gif
Old Sep 30, 2005 | 08:36 PM
  #28
silvertibbs's Avatar
Vehicle: 2004 Acura TL
Dunno man, depends on the TC I think. You got a T3 super 60 no? If so, you might be able to get a new one fairly cheap.
I think the other larger ones might be easier/better to service as they are more expensive to but new. So the cost may be lower to replace seals and such.
Old Sep 30, 2005 | 09:34 PM
  #29
hamhead's Avatar
Ye.... it's going to run ~300ish to rebuild it, which is about the price of a T3 Super 60 if thats what you run.
