Cheap way around an FMU or RRFPR
Old Oct 20, 2004 | 12:49 PM
krazykyle's Avatar
Default Re: Glass packed muffler question
Well i found a 1g turbo fpr and i was planning on getting little bit larger injectors if you could check on the 1g for me that would be awsome.
Thanks.
Old Oct 20, 2004 | 12:59 PM
OdessitPashka's Avatar
Default Re: More Exhaust Help
so are you saying that just having that FPR, and larger fuel pump would give us enough fuel for 300whp? you will need to upgrade your injectors as well.
so basically the dsm fpr will be just as good as any other aftermarket fpr? and all you need is a set of injectors, new pump, and somthing to control injectors!
but I think you can achieve the same results with just a bigger pump, SAFC and a new set of injectors. I don't think that our stock fprs are too restrictive.
is the DSM fpr adjustable?
Old Oct 20, 2004 | 01:41 PM
Dweet's Avatar
Default subs playing with head unit turned off....
QUOTE (OdessitPashka)
I talked to some local DSM'ers, one guy is running mid 12's with his stock 2G FPR in his Talon TSi. Only downside its not adjustable. However this same guy is running a Walbro 190 fuel pump. If you go to a Walbro 255 or any higher flowing pump you WILL need to upgrade the FPR to an aftermarket one, I recommend an Aeromotive.
But yes the FPR is as good as any aftermarket FPR as long as you use the Walbro 190.
As far as hitting mid 12's with a pump, AFC and bigger injectors, ehh doubtful because our MAF sucks. It uses a 1v - 5v reading. The Karmen MAF that DSM's use talk to the ECU in a totally different manner. It uses a Hz scale and not a V scale which makes it alot better.
Anyways the setup that the DSM'er that I talk to is running 550cc injectors, Walbro 190 and stock 2G FPR, oh yeah he is using nitrous as well but is hitting those numbers with a stock 14b turbo as well I believe.
Old Oct 20, 2004 | 02:02 PM
Default Re: new owner, need advice
I know about our MAFs, but I think i will be using an aftermarket FPR with 255lph pump eventually, now I will be good with FMU
Old Oct 20, 2004 | 02:09 PM
Dweet's Avatar
why would you fork out the bucks for an FMU when you can get a DSM FPR for like $20 off of dsmtrader.com
Old Oct 20, 2004 | 04:37 PM
Default Re: Vibration while in neutral
I bought it a long time ago, and FPR will not do the job of FMU, it will not raise the pressure high enough to support all extra air added unless you have bigger injectors.
Old Oct 20, 2004 | 04:44 PM
Dweet's Avatar
Default Re: Gmail
if its a 1:1 FPU its going to do the same thing as these DSM FPR's.. Also you have to remember if you are using a 190 the pressure will be even higher, I really dont see an issue with it.
Old Oct 20, 2004 | 04:46 PM
Default Re: Get a free Ipod!!!
mine is adjustable cartech FMU, from 2:1 to 12:1 ratios, and for now I will be using stock pump.
Old Oct 20, 2004 | 05:00 PM
Dweet's Avatar
Default removing break Calipers
ahh then you would be better off with that
Old Oct 22, 2004 | 12:09 PM
Dweet's Avatar
Default Re: Blue and Amber Haloz
*bump* to let everyone know that the 1G DSM FPR will work as well...
