Dyno On Headers
Old Apr 19, 2006 | 11:42 AM
I'm wondering if there's any dyno results available for any headers out there. I've heard there are NO dyno results which proove any header is better then a manifold. I'd like to see some.
If there are results availble, then they need to be more then 10HP because you can get those results from a simple ECU reset.
Old Apr 19, 2006 | 11:51 AM
Shit, I'll be right back guys, I'm gonna go reset my ECU 40 times so I can have the most HP in the world.
Old Apr 19, 2006 | 12:00 PM
homey14h's Avatar
^^mad_john would still own you haha.
Old Apr 19, 2006 | 12:04 PM
<div class='quotetop'>QUOTE (REDZMAN @ Apr 19 2006, 12:51 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Shit, I'll be right back guys, I'm gonna go reset my ECU 40 times so I can have the most HP in the world.</div>
don't be rediculous... The emissions/engine control unit adapts it's output to run clean. after it adapts there's some horse power loss. that's how every mod claims 10-15 HP gains. If each mod actually did give that much HP then people would be running 300HP on NA mods from stuff on ebay.
results?
Old Apr 19, 2006 | 12:12 PM
tanc's Avatar
Vehicle: 1997 Tiburon
Please educate yourself on the matter first before you state rediculous comments on a ECU reset.
If you have a dyno vid to prove resetting ECU will give YOU 10whp, I'm going to follow Jeremy's advice and reset my ECU everyday.
Old Apr 19, 2006 | 12:19 PM
Rediculous? done one lately? Redz stated once it should be done once a month. The reason for that is because the ECU adapts fuel output to temp, load, gas quality and emissions output from O2 sensor. It's a noticable difference when I do a ECU reset. After break-in procedure is completed, the engine settles down to it's normal operating procedures.
Old Apr 19, 2006 | 01:40 PM
Dmitry's Avatar
Vehicle: Elantra HD / 2007
it may be different in closed loop, but as soon as you hit open loop there should be no gain at all from reseting ECU.
correct me if I'm wrong.
Old Apr 19, 2006 | 01:57 PM
tanc's Avatar
<div class='quotetop'>QUOTE (DrivingTibNaked @ Apr 19 2006, 02:19 PM) <{POST_SNAPBACK}></div><div class='quotemain'>Rediculous? done one lately? Redz stated once it should be done once a month. The reason for that is because the ECU adapts fuel output to temp, load, gas quality and emissions output from O2 sensor. It's a noticable difference when I do a ECU reset. After break-in procedure is completed, the engine settles down to it's normal operating procedures.</div>
Yes your correct but it doesn't give you 10whp LOL. We don't drive 5.0L Mustangs.
The most gain being generous I'd probably guess around 3whp. If you can proove that you'll get more then 5whp than I'll shut up and let you educate me.
Old Apr 19, 2006 | 02:05 PM
ok, basically, i'd like to see ECU reset with manifold, then ecu reset with headers so there's no differential from set adaptive values after 2 drive cycles. Reason being that you're going to reset the ECU after a mod such as headers anyways and it gets rid of the varriance because adaptive values are still set to default.
Old Apr 19, 2006 | 02:36 PM
tanc's Avatar
Yup, but whose got money to dyno pointless things like that?
Anyone have a g-tech?
