rd or rd2?
i think thats what i said. haha
i said on RD's, do NOT take off the screws. on RD2's you can.
oooooh, that explains it better for me (and i'm sure for others). i thought that on Captive rotors, it was the same thing as the Screw on RD2s.....just went deeper into the hub
QUOTE (tibby01)
they contain big bolts in between each wheel stud that hold together the whole hub/spindle/rotor assembly. you CANNOT remove those.
QUOTE (Shark01Racing)
is there a VIN code to figure that out?? my manufacture date was Sept of '01 i believe (i'll have to check on that...but not now, it's raining and i don't wanna get wet). would that be a "end of the line" one?
I don't think so, a bit further. Mine is a Sept 01 MFR date and has a Beta 1.
QUOTE (tibby01)
NO. DONT DO THIS!!!!
the two screws that are on NON-CAPTIVE rotors you can remove. they are apparently used just in the assembly line to hold the rotor on to the hub.
CAPTIVE rotors are much different!!!! they contain big bolts in between each wheel stud that hold together the whole hub/spindle/rotor assembly. you CANNOT remove those.
Correct. When you take your rims off you'll see 2 small phillips head screws on the face of your hub. Those can come off.
Originally posted by 4doorGL on HA.com:
[QB] Captive: The bearing is pressed into the rotor. The rotor attaches to the spindle, then the hub is pressed into the rotor, holding it to the spindle. Here's a pic:
The left setup is captive (the stock Accent brake), the right setup is non-captive (brakes from a 2001 Tiburon). [/QB]
Personally, RD1's for looks but late 2001's for all the newer upgrades, like the better shifter,... One thing I Don't like, on is the 2 cat Cali emmissions on the 2001's though!
Draw backs of RD1s:
97: shifter sucks, Evap Canister, Captive Rotors
98: Captive rotors
99: Best RD1's wink1.gif
When I got mine, the 00's just came out and I had a choice, but the bug eyes on the RDs just turned me away. So I got my 99
And Andy: There are NO BETA II's in RDs in North America. I have NEVER seen one. BETA II's started in the Elantra XD's. In Europe or where ever else, there might be,... Heck in Europe, they have a 1.6L GK you can get,... why you'd get a 1.6L 3000lbs car? I dunno.
Draw backs of RD1s:
98: Captive rotors
well looks like i shouldnt have any fitting myself into the car issues smile.gif
from what i understand captive brakes are only on the rear wheels, and its pretty much what i have on my xd, its just drums, or im wrong?
does anybody have rd1 with high milage and has any problems with it? since i dont have that much money to spend i will probably end up gettin a high-milage car
like this one
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...RK%3AMEBWA%3AIT
or this one
any comments will be appreciated
like this one
or this one
QUOTE (tibby01)
only the fronts are supposed to have calipers.
WTF?
No offence mang, but you have 4 wheel DISK brakes.
Calipers are what make you stop, you push the pedal, the calipers push the pads onto the DISKS.
Maybe there is some confusion here?
