KFX Performance
Sponsor:    KFX Performance
R&D for your Hyundai, new parts development, Colt Cams, tuning Korean Cars for almost 10 years.
http://www.kfxperformance.com/
Engine Dampers? Kfx Performance...
Old Apr 19, 2009 | 12:31 AM
  #581
Really?
Wow, got pics?
I hadn't had any problems with mine yet. My hood rattling on my strut bar is pissing me off though.
Old Apr 19, 2009 | 02:20 AM
  #582
one of mine stripped out. I tapped it and put in a bigger bolt. My bracket is gusseted and stronger then most though.
Old Apr 21, 2009 | 05:55 PM
  #583
radu_rd2's Avatar
Vehicle: 2006 Pontiac GTO
I replaced the bolts, the correct size to use would be M8 x 20mm. (I had 25mm but had to use a couple of split-lock washers).
It's a good idea to change them, also because the stock bolts are kinda short (bracket is pretty thick).
Old May 9, 2009 | 08:54 PM
  #584
gophins349's Avatar
i just placed a order for another one...i had issues with the first one i had.
carbon fiber damper
paypal
Transaction ID: 58X38745JH157745W
i am hoping to get it by friday
thanks
Old May 9, 2009 | 09:28 PM
  #585
What happened?
Old May 10, 2009 | 06:32 PM
  #586
gophins349's Avatar
it was really my fault.. i took it apart and i think i lost a piece cause it doesn't work like it should.it worked great before put there is no pressure when i push the ends together it just collapses. plus when i first put it on it doesn't fit below the bracket cause of my cruise control so i had to put it on top and it ended up coming apart cause it was bending a weird way. so now im just going to get some kind of spacer/washer to put under the bracket on the engine side so it will sit up a little more. i also thought it would be a good idea to superglue the one end shut. so now i cant even open it back up haha
Old May 10, 2009 | 06:45 PM
  #587
If you send it to me, I'll fix it for you and loctite it shut. I had difficulty putting mine back together one time.
Old May 10, 2009 | 11:28 PM
  #588
gophins349's Avatar
I will send it to u if u want but I can't even open it back up cause I used a few drops of super glue now that sucker is tight haha.
I think it just needs a washer inside of it. I think that was the part I lost when I took it apart
Pm me if u want me to send it to u.
Old May 14, 2009 | 07:36 PM
  #589
gophins349's Avatar
Hey Bill
can you let me know that you received my order for the damper i never got an email confirming it from kfxperformance just from paypal
thanks.
Old May 14, 2009 | 08:36 PM
  #590
bhurlin's Avatar
Vehicle: 1999 Kia Sephia
Got it and shipped it
Your order that is
